Brad Jones
Since it looks difficult to find a path to lead halyards back to cockpit on 1985 Oday 26, I will probably put 1 or 2 winches on mast. How do you bolt teak base block to mast (put winch bolts all the way into mast or use separate bolts inside block tapped into mast). Will tapped threads in mast hold winch load??
