Winch slipping
Dec 22, 2012
102
Islander 30 Bahama Keyport
Apparently no good deed goes unpunished. I elected to clean and re-grease the winches since I had no idea when the PO had done so. At the first sail after the cleaning, both winches began to slip back after winching in the jib sheets. I was even to do replicate the problem when they weren't even under a load. I opened and rechecked the assembly and everything appears in order. The one thing I did not do was replace the pawl springs with new ones since the existing ones appeared OK. Is it possible that the springs are the problem? I've purchased replacements but haven't had a chance to install them but wondering if that's even going to affect a change.
Ted
Jan 26, 2005
1,278
It sounds like you may have put the pawls in backwards. On some winches they can be put in two ways and still look almost correct. All will be fine until you start using them. What model winches did you service?
Joe
Jun 1, 2004
8,318
What type of lube did you use on the pawls?
My immediate thought also..... pawls are stuck because you used grease instead of light oil. In any event, you'll have to remove the drum again and redo the pawls. It's not the springs, it's either the incorrect re installation of them, or grease on the pawls.
Dec 22, 2012
102
Seems like the consensus is I got grease on the pawls. I used Lewmar winch grease for the gears and Lewmar oil for the pawls and thought I was using them sparingly. Apparently another disassembly is in the cards!
Thanks for the feedback.
Gunni
Mar 16, 2010
5,937
Did you do the job right?
It is relatively easy. If you do it right.
Gunni
Mar 16, 2010
5,937
So, if you watch the Lewmar video you would have the answer to your own question - replace the pawl springs EVERY TIME you strip and clean your winches.
Dec 22, 2012
102
Thanks, Gunni. I plan on replacing them as well as giving everything another thorough cleaning. I should be able to do it with my eyes closed by now...
Dec 22, 2012
102
You can't fix stupid....
Just thought I'd report in that I did indeed screw up and installed one of the ratchet gears upside down. Flipped it over and everything works like a charm. Another ten minutes to do the same on the other winch and life is back on track.
Thanks to all for your patience and advice!
Nestor
Nestor, that's great. Glad it finally worked, and thanks for your honesty! Believe me, please, that almost all of us here know EXACTLY how you feel, and how you got there. :):):)
All the best.
