My Winch Rebuild
Several years ago I rebuilt the winches on my 1970 Catalina 22. They were Barlows, but I don't know the size. I used the Harken rebuild kit from West Marine, which consisted of extra pawls and springs, and bearing lubricant. I left the winch base in place and took the drum off. Parts were pretty dirty and the springs either broke or were mangled. I cleaned the bearings and other parts with mineral spirits (denatured alcohol does not work). Once they were clean, the original pawls looked ever so slightly shorter than the Harkens, but they didn't look too worn, so I reused them. I did replace all the springs, relubed the bearings, and reassembled. They have worked fine ever since.
