winch on aft side of mast
Jan 13, 2013
3
Hunter 27 Cherubini Seattletown
on the H-31, yrs 83-87, there is a winch and winch pad on the aft side of mast just under the boom with a slight downward angle-what is it's purpose?
Hunter 34 Alameda CA
Some folks had difficulty reefing with the system provided (not a single line reefing system) and added a winch where you describe. We were taught how to manage the sail with everything slack (mainsheet), sailing close reached to the wind, and the topping lift fully raised. So a winch for us was unnecessary. After securing the luff cringle to the gooseneck horn and tightening the halyard a bit, the reef line is addressed. I pull it to get the leech down to the elevated boom as best I can then form a loop and stick my foot into it to cinch it down the rest of the way. Then I engage the jammer to keep it from slipping then dump the topping lift and sheet the main in.
HMT2
Mar 20, 2014
899
Hunter 31 828 Shoreacres, TX
I've used it for the outhaul. It can be used for a halyard as well. But I've used it maybe three or four times in the seven years I've had the boat. BTW it's an '83 H 31.
