Winch Cleaning Solution
C
Captn Bob
I presently have four of my Lewmar winches sitting on the shop stand waiting for their spring cleaning. To do a really good job of cleaning the winch post, gears etc I am giving consideration to taking the parts to a Radiator Shop and let them clean them up in their soup. See any problems with the Lewmar parts in this cleaning compound ??> Also my self tailing winches do not have the new feature that allows differnt sicze line to be gripped by the upper jaws. Believe it is called Wavespring - is this feature available for the older 40 and 46 and 37 winches (circa 1986) ???
W
Warren M.
Winch Cleaning
I don't know what shape the innards of your winches are in, but taking them to a radiator shop sounds like expensive overkill. Why not just soak the parts in either mineral spirits or ordinary diesel fuel for a few days, clean them up with a an old paint and or toothbrush, lube them with some lithium grease and put them back in service?
Mar 14, 2005
0
- - Lewmar
Agree with Warren
Captn Bob, I agree with Warren on this one. You can also clean the nasty grease off with an old rag and then get them clean with WD-40. Just remember that WD-40 is only a cleaner and not a lubricant, be sure to have the correct oil and grease for proper lubricating. As to the wavespring jaws. They do not retrofit. Sorry... Happy Cleaning.. www.lewmar.com
F
FOAMY
BIO DEGRADEABLE DEGREASER
I'VE BEEN USING A BIO DEGRADEABLE DEGREASER TO SOAK AND CLEAN MY WINCH PARTS FOR YEARS. NO FIRE HAZARD OR CAUSTIC BURNS OR SPILLS TO WORRY ABOUT. I JUST FLUSH THE DEGREASER OFF WITH WATER, AND BAKE THE METAL PARTS IN THE OVEN AT 250 TO INSURE THEY ARE DRY; PLASTIC PARTS I TOWEL DRY. WORKS LIKE A CHARM.
