Barry
A friend of mine has a trailer for a 1994 HUnter 26, Water ballast. I wanted to purchase it and modify it with some support pads farther out to the right and left for my 1987 26.5. The trailer is rated for 7000 lbs. The beams on both boats are about the same at 9'. The lengths are comparable. The 26.5 has a fixed keel with a draft of 3'6" the water ballast has a 1'9" draft with the center board raised. Does anyone out there know if this will work?
