Agree Somewhat
A small electric or trolling motor will only work well under ideal conditions. I only use it as a backup. (See my previous posting). Under high winds, i.e. 15k or greater it is very difficult to handle. I don't have a noticeable current. You pay a high penalty for trying to go faster with a larger motor because of the current drain. You can calculate, roughly, how long your battery will last. Look at the AH rating for the battery. The larger 12V marine batteries are 100AH or more. In the example I gave, you could run for about an hour or so at 5k. If that is adequate, you are in business.It is fun to motor into the marina under electric power. The other sailors are not quite sure what to think.
