Wifi router 12v
Oct 17, 2011
2,809
Ericson 29 Southport..
cp, that was a heckuva informative post, and sounds like my "issue" exactly.
Hmm, flashing blue LED, huh? Man....I've already thought of about five crazy tales I could put on people with that. 'That's fiber optic laser radiation, ma'am. Please stand back'..
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
I considered a "Bullet, etc", wi-fi extender, but,
now, when we go cruising, I just activate the Wi-Fi hot spot on my Verizon cell phone (for $15/mo, I think). Simple, no new equip to buy, install and configure, and it works fine. Don't have to worry about finding the elusive "open" wi-fi signal.
Am I missing something ?
yes. $15 a month ;)
Actually, as long as you're able to connect with your cellphone wherever you are, and you're happy with the bandwidth, it's a very reasonable solution.
Oct 17, 2011
2,809
This was posted elsewhere, but the Bullet is IT! I used Bob at Islandtime PC. $250.00 plus 16 bucks shipping. A whiz-bang install, that is worth every penny and then some. I'm a huge fan of non aggravating equipment. Plug. Play. Fergit it..
(And when Rich and Wayne went there, (the bullet), that was enough for me. I try and emulate smart people, thereby making me appear less stooopid)...
Bonzai
Jun 23, 2009
250
Chris-Craft SailYacht 35 St. Simon's Island, Ga.
Happy "Bullet" user
I'm looking at putting a wifi router onto my boat.
Ideally something that will also pick up shore based wifi as well.
Is there such a device? Has anyone installed one?
Do they come with 12VDC input voltage?
Thanks
Simon
Kordie, I have used IslandTime PC's "Bullet" set up without any trouble for over 2 yrs now. It is pretty darned amazing. Complete outfit available and CS is best I have ever had.
Feb 2, 2010
373
Island Packet 37 Hull #2 Harpswell Me
Do you use an I-Phone or similar smart phone? If I'm at a marina with wifi I just connect to that. Otherwise you can do what's called "tethering" with your i-phone. Simply turn on the "Personal Hotspot" option in the settings on your phone. It will then create a wifi hotspot using your cell signal. You can connect any wifi capable device to this hotspot and you're off to the races.
That is not an option on US iPhones. I know it is available on phones sold in the UK but disabled in the US for some reason.
Tim R.
May 27, 2004
3,626
Most any smartphone in the US is capable of being a hotspot. You just have to enable it with your carrier. It will likely cost you extra.
Dec 2, 1999
15,184
We use FoxFi on our Android phone to create a hot spot. I does not cost us anything additional with Verizon.
There were other options that did cost a monthly fee.
Dec 2, 1999
15,184
You can always use a cheap inverter and plug it into to a 12vdc outlet to try it out. These solutions are a lot cheaper than the "boat" solutions.
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
I'm looking at putting a wifi router onto my boat. Ideally something that will also pick up shore based wifi as well.
Not sure about all of them, but the Linksys routers use a 12vdc wall transformer, so it would very easy to hook one up to your boats battery.
Haven't done it in a boat, but have in an RV.. I have an older linksys (Wireless-G) that I picked up off Craiglist for $15 and converted into a repeater using DD-WRT software flashed into it. Works great and lets me 'borrow' other peoples internet connections when I don't have one of my own. Range can be further increased by the use of a high gain antenna like a cantenna or similar.
Cheers,
Brad
