Wifi Boosters
Mar 16, 2009
5
Hunter 35 Coconut Grove
I made a homemade wifi dish by taking a large metal strainer, cutting a small hole in the middle, and gluing a USB internet receiver into the center of it (connected to the computer by a USB extension cord). Then I clamped the handle of the strainer dish onto a clamp-on flexible arm I got off a cheap clamp on light you can buy at the "Marts" for $8. That way I can bend and twist the dish towards the source to get the best signal.
I don't have the means to do any specific testing, but it certainly seems to make a noticeable difference, in that wifi sources registered a couple bars better reception than without the dish. Here's a page of a guy who did something similar: https://www.hackthissite.org/articles/read/1129
Jun 13, 2015
12
Newport Holiday 20 Lititz, Pa.
A friend and I were just speaking of such things last night - though not in relation to boating. He has one of the(Below) mentioned devices - which works fine - with no Ethernet connection to an internet source - though that can be done, as well, if you have "Cable or DSL". He used his to "take advantage of Wi-Fi that may be available", until he signed-up for service - which he did - eventually...(Get me?), though should work fine for what you are speaking of, as well. In other words, you may not always/ever use the standard router-to-modem functions it can provide, but, for the price/size/potential of the repeater section, the normal, Ethernet functions take-up little extra space - just looks like/is, also, a normal router, if/when you can "plug-in".
So, add to your List of Wi-Fi "boosters" to check-out -
Hawking Technology HAW2R1
There are several other models - some made to be "completely" outside mounted(12v? Don't know..? HAW2R1 is a "wall wart" unit, so maybe, it, too, could be used with DC..?)...
It's not a booster, perse - though it is... It does the booster-thing a somewhat different way - which should eliminate the possible difficulties of "standard" boosters, which try to amplify the channel you are trying to use(Sometimes with unsatisfactory results.)... This model is a rather standard router, with dual-diversity antennas(Long used for wireless microphones, etc. Wi-Fi calls it "MIMO"), to "choose" the best signal getting to wherever your device is, in relation TO the router. So it has two antennas to distribute Wi-Fi to your devices - a feature seen on many routers, today. However, this unit has a third antenna AND a separate transmitter and receiver, acting as the "repeater", that, rather elegantly, "creates a whole separate network"(Read-up on it.). The "R1" model has a "high-gain/directional" antenna(Others available - whips, outdoor, etc.), FOR the "separate" network it establishes for itself(Changes nothing on how you use your devices to "do" Wi-fi.). Though much of the high-gain is likely provided by simply putting the antenna outside or up higher, or in a "better spot", using a coax cable from the unit, rather than the usual antenna stuck on the back of the router under a table, it should be "better" all the way around.
The "extra hardware" on the hawking device is remindful of the old "Wi-Fi PCI cards", used before Wi-Fi was put into most devices, to get Wi-Fi from "some other wireless modem" - maybe even in your neighbors house..?
All that said, you may appreciate having a "real computer" available to set it up, on the web(Often easier and more comprehensive - more settings - though you can set it up simply, from it's own CD, as my friend did - he had no computer, only phones, at the time.) - just like any router.
A very non-precise explanation of what it does would be that the unit gets it's Wi-Fi, from the marina's router(Say, "Channel 6" - whatever?), in the low router band(2.4Mhz.), then, converts and distributes it to your devices on "some other" Wi-Fi channel, automatically(Same band. Say, using Channel 11, instead.), so you have a "clean" Wi-Fi channel of "your own" to use, while it "hides" Channel 6, from your devices "available Wi-Fi" view - you, just "logging-in" as normal, first, to the marina Wi-Fi, then, your devices to YOUR Wi-Fi. So, yes, a bit more "fooling around". Though, again, should work better - potential for hundreds of feet better! And be simple enough. Matter of fact, you could "allow distribution" to other friendly boats, nearby, by shouting over your log-in info, to aid in their suffering, as well - though it also offers all the usual security features.
Worth a look. "Search" Hawking Technology - their devices available lots of places. Basically, a "300N" router, with "repeater. May do the trick. Price - quite reasonable. "True Outdoor" models not quite so "quite", though still reasonable.
By the way - When you run into poor Wi-Fi at a marina(Camp Ground, etc.), you might suggest that the owner investigate one of these widgets for their use? To any visitor with the password(Or if left "open"), it may improve Wi-Fi for the whole place - over just opening-up his "normal" router for customer use, again, at a reasonable cost.
The addition of one or more of these widgets around a large space could be just the ticket.
On the other hand(As inferred, above.), IF you have a modern Wi-Fi router, with "removable/changeable" antenna ports(SMA-type jacks?), ANY "gain/directional" antenna(Cheap to pricey!) to replace what's there now, or, even putting a coax cable on the router, then running the cable to a window and attaching the router's own little "rubber ducky" antenna to the end of the cable, may provide a considerable boost in signal with no further effort, at all.
Jul 26, 2009
11
HUNTER H30 FR kootenay lake
Hi
I would recommend using a rogue wave.
I have one on my 42 passage in Abaco Bahamas, good improvement to get as much signal as being broadcast.
Cheers
Ken
Jul 27, 2015
1
Hunter 31 Marina Del Rey
Good Booster
While my son was overseas and was getting a lousy connection to the one wifi spot on base I sent him -
BearExtender PC USB WiFi Booster and Range Extender for Microsoft Windows
this did the trick - but velcro it down so it can't hit the floor.
cheers
May 28, 2010
3
Oday 272 Merritt Island, FL
Any recommendations on Wifi boosters. The family loves their Netflix on personal devices and our marina's wifi is just a bit weak. Would also like to use when on guest moorings when traveling.
Best brands and best mounting locations appreciated.
Thoughts??
Some time ago Blue water Sailing (April 2014) had a good article on boosters by Daniel Collins. He talked a lot about antenna gain and how to much isn't good if you're rocking and rolling on the hook. There it states an antenna gain between 4 and 6 dBi is best. As you increase the antenna gain the degree of view above and below the horizon decreases. A 8 dBi gain antenna only sees about 10 degrees above and below the horizon. If the boat is pitching/rocking you'll likely lose the signal often.
The three units they discussed were the Rogue wave, The WireAP, and the DigitalYaght WL510. For my application I choose the WireAP, it checked all the boxes for my install. Another consideration is the mounting of the antenna, for me mounting it on a spare halyard so I can adjust the height to gain max advantage (clear line of sight over neby boats or buildings) works best.
It may be worth geting a reprint of BWS April 2014 to gain an understanding beyond my explanation.
Good luck,
George
Alan K
Feb 22, 2004
56
Hunter 380 Norwalk, CT
I installed PDQ Connect's AllPro antenna/router package. Simple install. Antenna and Router are set up before shipment, so it's really just plug-and-play. Most of my use is pulling in a signal when anchored out. Very happy with the product.
RIlulu
Feb 27, 2005
3
Morgan 462 Barrington, RI
We installed" The Wirie" on the "roll bar" on the aft deck. Only needed power source- otherwise wireless. Worked great in the Bahamas and actually forund sites which were not secured to use. Easy to manage and price was right.
Sep 16, 2013
11
Wauquiez 43 Amphitrite Stuart
You should check out http://www.jefatech.com They sell a Repeter for RV's that I have been using on my boat for over a year now. It is a re-worked wifi router with an external antenna. The signal in my marina is fast but very week. This unit gives me full bars on all of my devices onboard. It's under 200 bucks, and worth it.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Sep 20, 2013
12
Islander 37 Seabrook, TX
The wi-fi at my marina is so slow that it is useless, even in the slip. I just started using the Mobil Hotspot feature on my Verizon phone. I haven't tried to use Netflix, but for everything else it is quite fast. It works everywhere there is cellphone service, and on my plan it is free.
Nov 26, 2008
1,970
Endeavour 42 Cruisin
Installed a Ubiquiti Bullet that I bought in a kit from Bob at Island Time PC in 2009 on the first spreader. Has been working fantastically ever since. We full time cruise. Spend time way out on the end of a mooring field and pull in the wifi when many others close in say they cant. Pull in hot spots from a pretty long way off in a variety of places on the US east coast and Bahamas.
Bob at Island Time PC was extremely helpful with all my questions and his prices were very good.
Excellent vendor.
Jun 2, 2004
45
Catalina 400 Muskegon, Michigan
I have a unit called a "Wirie." You can find it online just by putting wirie in a search engine. We use it all the time. For example when we are cruising on Lake Michigan we will sometimes anchor in the outer harbor between the breakwaters. Without the Wirie we get no wifi signals at all. With it we get about 30 different sources with many of them unprotected (restaurants, hotels, motels etc.). We're not looking for lightning speed, we just want access. Check them out online...
Feb 23, 2011
8
Hunter 466 Singapore
Like a number of responses , we use a Ubiquiti Bullet , 8db (if I recall) unidirectional antenna to pick up the wifi and then rebroadcast it on the the boat on an Apple Airport Express. Biggest challenge was to procure weather proof ethernet cable to wire the boat and high quality stainless mount for the aerial.
Also noted elsewhere , took a bit to figure out the set up, but there are numerous articles on how to do this. If you do more than 25% of your boat maintenance, including electrics, you most likely can master this.
We do most of our sailing in Thailand. Whilst 3G (and 4G) is becoming more available it is still expensive for lots of data. Venue wifi is common. So typically when we anchor we do a mini bar crawl and find the best wifis to bring back to the boat. That in itself can be so much fun we sometimes forget about the wifi.
Catalina 30 Mandeville, La.
I would just record or copy a lot of movies and shows you like and keep on a hard drive. Get something like the Ubiquiti Bullet for the rare occasion that you can actually stream video and finally use your wireless data. If you have a small library of videos, you shouldn't have to stream video daily and may not kill your cellular data plan as quick. Just surfing won't eat it up too quickly unless you keep returning to the Boat Babe on Strike thread...
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
I just added a can from beans to my TP-Link. I drilled a hole per these instructions and picked up another bar.
http://www.shtfpreparedness.com/build-tin-can-wifi-antenna/
All U Get
I happened to use Bush's large can.
Jul 28, 2015
4
Catalina 250 Essington, PA
Go cheap with the booster equipment
I have a few points to add.
First, marina Wifi service is notoriously poor. Usually the marina staff lack the tech skills to optimize it for good bandwidth, making silly errors like picking the same channel as the marina next door. The rare one that has good tech skills often will throttle back the bandwidth of individual connections to make sure everyone can get their share. So it is very possible that a booster will not give you sufficient bandwidth to stream video. Before wasting your money, you should take your laptop, tablet, or smartphone over near the Wifi hotspot and run a speed test. No booster will improve on that. You hear all these people raving about how their booster gave them "5 bars." Of course your device's connection to the booster is going to have 5 bars. That doesn't mean the marina's Wifi is going to be any faster. With a good antenna you may get less dropouts, but not necessarily faster. And as someone else pointed out, high gain is not always better because it typically is more directional, and a moving boat - even just pitching in a wake - will lead to dropouts.
Second, as someone else said, open Wifi hotspots are more and more rare. I would advise against spending $400 or more on a marine grade booster that may be useless in a couple years. For most people, I would recommend a non-marine consumer-grade device for $30-100.
I am able to pull in weak signals that my devices normally cannot with a simple and cheap non-marinized booster such as this:
http://www.amazon.com/Alfa-AWUS036H...d=1438008401&sr=1-9&keywords=usb+wifi+booster
I have had this same USB antenna for a few years, and while it served me well on my old Windows XP netbook, the drivers were always a bit funky. And driver support for Windows 7 and 8 is even worse. (I could never get it to work on Windows 8.1.) I recently replaced it with this more up-to-date model from the same company, which is based on a newer chip that supports 802.11n over 2.4 GHz:
http://store.rokland.com/products/a...1n-long-range-wi-fi-usb-adapter-5-dbi-antenna
FWIW, I do not recommend the dual band versions of this amplified antenna. Many dual band antennas get very poor performance with older 802.11g routers (significantly worse than g antennas), so you should not use them unless you are sure you will always be working with an 802.11n router. Many marinas do not have n routers, and the ones that do often have them configured incorrectly. So you're much better off sticking with a single band (2.4 GHz) antenna. This issue is explained fully in the product descriptions on the Rokland website. I strongly recommend buying from them because their tech support response has been outstanding for me.
Of course, plugging in a USB antenna can be difficult with an iPad or smartphone. And the driver situation can be frustrating. So Alfa also makes a model R36 router with USB input that is specifically designed to mate with the AWUS036NHR amplified antenna:
http://store.rokland.com/products/alfa-r36-awus036nh-awus036nhr-wi-fi-wireless-router-ap
By mating the AWUS036NHR antenna with the R36 router, you eliminate the need to install any drivers on your PC, Mac, tablet, smartphone, or any other devices. You just connect to the hotspot by Wifi and go to the configuration page to log into the marina's network.
The R36 router also supports plugging in a 3G/4G wireless USB dongle for sharing among multiple devices. So if you have one of those, you can use it to share your wireless service among multiple devices. I have not actually tried this, though.
... I also use a free little utility on my netbook called "MyPublicWifi" that allows multiple users to connect to the booster. There are many other solutions. This is just one that fills my needs at low, low price.
http://mypublicwifi.com/publicwifi/en/index.html
I've played around with Wifi sharing utilities on my computers before. It's built into most versions of Windows, and also available from third party sources like the one you linked. In my experience the external router like the R36 is much more straightforward and worth the money.
The USB antenna + router is under $100.
Other accessories that I suggest are an amplified USB extension cable and a remote antenna stand. These will allow you to place the antenna outside while the router stays inside the boat. Also, some additional screw-in antennas are a good idea (try them all out and pick what works best). You can get better signal from a directional antenna, but only if your boat is in calm water. The 36NHR amplified antenna is available in a kit that has some of these accessories included:
http://store.rokland.com/products/alfa-awus036nhr-2000mw-usb-wi-fi-luxury-pack-w-5-accesories
Also, the R36 router works off of 12v, and provide power to the amplified antenna over USB. You can buy a 12v adapter for about $10 if you don't already have one lying around.
EDIT: FWIW, the same company also makes an outdoor amplified antenna. I have not used it, though:
http://store.rokland.com/products/alfa-tube-un-802-11n-outdoor-long-range-usb-8-dbi-antenna-kit
Gunni
Mar 16, 2010
5,937
Yeah, tell them the technology is not available, and nip this stuff in the bud. You're the captain, not the Director of IT. And it's a boat, that's the ocean, and we're making our own movies.....something like that. You have to get this crew whipped into shape Monterey!
Jul 28, 2015
4
I realize that your post is tongue-in-cheek, but it does hit on an interesting dilemma. Many of us go sailing to escape all this stuff. But for those who are parents of kids who might be easily bored and not so excited by sailing, we need to try to keep them wanting to come along, so some technology is helpful. Deciding where to draw the line is an interesting challenge.
