I have 2 questions related to my used, probably
1972-73 Widgeon that I bought last year. First relates to the boom out-haul for the main sail. On the Widgeon's boom there is a fitting at the end of the boom (see pix out-haul). One is the connection point for the main sheet. That's straight forward. However, I'm uncertain as to how best to tie-off the out-haul line on the foot of the main sail. I can loop the out-haul line through the fitting but there is no way to tie it off. On a prior sailboat there was a cleat on the boom for this purpose, so I'm thinking of adding a cleat to the Widgeon's boom. Does anyone know what is the recommended method to tie-off the out-haul line?
Second question relates to a line attached between the centerboard trunk (top) and the boom with some unknown fitting (see pix-1, pix-2 & pix-3). I'm guessing it's some down-haul for the boom but I'm uncertain how to use it and how it should be rigged. The fitting at the centerboard cap has a swivel pulley. The fitting on the boom has a hole in one end of it and a V-notch on the other end.
Thanks for any help.
