Why use h260 rope jib halyard to raise mast not my roller furler wire stay?
Oct 8, 2023
116
Hunter 260 Kemah
Why use h260 rope jib halyard to raise mast w gin pole, and not roller furler wire stay? Wire seems stronger than 5/16 rope or often 1/4 rope.
Joe
Jun 1, 2004
8,346
When you say "roller furler wire stay" are you referring to the forestay? Is that the one that you connect to the boat to hold up the mast. If so, using it to raise the mast would require disconnecting the loaded stay to make the final connection. Also, for safety when, using this method, you would want to transfer the load to the halyard to hold the mast in place while you hook on the "RF wire stay". So.... using the halyard from the onset saves a step, and is safer. The rope is plenty strong enough to lift the mast. While line strength is mportant (your halyard rope is plenty strong enough to lift the mast) the most important concerns would the halyard block or sheave connection to the mast, and the connection between halyard and shackle. So, inspect both of those, especially the halyard shackle. The best connection is the D shaped, captive pin shackle attached to the halyard rope with a halyard hitch or a luggage tag eye splice.
or a luggage eye loop
  • Helpful
Facts beat “seems stronger”.
From Hunter Specifications for a 260.
Main Halyard
  • Material: 1/8" (3.2 mm) stainless steel wire
  • Breaking Strength: Approximately 1,780 pounds
If you are using lines that are offered here on SBO (not nylon lines bought at a box store), then you are getting Samson XLS3 Yacht braid polyester line with a Average Breaking Load 4100 lb.
If your boat is using OEM lines then they are still likely Yacht Braid polyester but the XLS lines then it would still have a bbreaking strength greater than the steel wire.
FROM: Samson Specifications. 5/16" Samson XLS yacht braid rope has a breaking strength of 3089 lbs.
As @Joe has shared, your halyards are more than capable of supporting your mast as you hoist it. Additionally you will find them a whole lot easier to handle than 1/8” diameter stainless steel wire. You can run them through a block and make you process even easier.
Even 1/4 inch diameter Samson XLS3 has a working load of 480 lbs (easily can lift your mast) and a breaking strength of plus 2000 lbs.
Likes: Timm R Oday25
Oct 8, 2023
116
Hunter 260 Kemah
My rope does look like 1/4 (4/16) not 5/16, so it does seem the OEM rope was thick 5/16 but over time switched to 1/4. . . Given the angles while lifting I think the force felt is many many times the mast weight, so using metal wire w gin pole seemed safer than rope. . . A person could add a thick rope looped horizontally around mast above the wing strut spacer thing, and have friend keep this tight in case the thinner rope breaks. My rope is old and I am cheap about replacing. D
Sep 24, 2018
4,752
Catalina 30 MKIII Chicago
Your rope may be stretched out. Perhaps it was 5/16 when it was new. In addition to the reasons mentioned above, you have a high probability of kinking your forestay. Those kinks never really come out and may affect the functionality of your furler
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
The main reason for not using the wire is it is too long. To completely raise the mast, the gin pole needs to remain at 90 degrees to the mast. That puts it at cabin height above the bow with the mast up. Any lower (if you used the wire) and the pole runs into interference before the mast is fully up. 10 years of using the rope haulyards to lift the mast, I never had a problem. As stated, low stretch yatch braid designed for haulyards has plenty of strength.
Oct 8, 2023
116
Hunter 260 Kemah
You are right, the bow is 1 foot lower than the mast step, so the wire running to perpendicular-to-mast gin pole end won't be taut. It can't be used ever with gin pole. Darn. .. . . . Rope can get old and weak, unlike wire. So darn.
pgandw
Oct 14, 2023
255
Stuart (ODay) Mariner 19 Yeopim Creek
If it's old and weak, time to replace it anyway. Rope is DIY, wire not so much.
I use the jib halyard on my gin pole for the reasons talked about.
1. Forestay is too long to use with gin pole.
2. I have an eye on the gin pole I clip the forestay to. That makes the forestay readily accessible when the mast is up.
Fred W
Stuart (ODay) Mariner 19 Sweet P
Oct 3, 2006
1,041
Hunter 29.5 Delaware city
I added baby stays, but no gin pole, to my old 23. The trick was never adjusting any stays- I would use the mainsheet tackle in between the headsail tack attachment and the jib halyard to pull the mast up. Before the mainsheet runs out of travel, stop, and finish raising the mast with the jib halyard. Then i could pretension the stays with a hard pull on the mainsheet, pin the forestay easily, and when it was all let off it was rigged and tuned.
