Also depends on your usage
I think you have to use your intended usage as a guide. For example, if you do a lot of offshore work, you need to put the dink up on deck. You can hang it on davits, but that has it's drawbacks also. Such as getting pooped, filling the dink with water and losing it. Also the hard dinks are usually quite a bit heavier, and a lot more work to get on deck. The best solution I have found is the inflatable floor models. They can be deflated, and rolled up on deck when needed, and are reasonably stable when inflated. Not as stable as a hard dink, but much more stable than a wood floor or slat floor model. A kayak also makes a good dink for some. Again, it depends on your primary usage.
