Hi All, Kinda new both to sailing and deisel engines, I have seen recomendations to change the oil when it comes out of the water in the fall, and again before it goes back in the spring. Can someone explain the reasoning for re-changing in spring when it hasn't been used except to fire it up to make sure the new impeller is in correctly, does the oil go "bad" over the winter? I have a universal 18 in mine, and want to do all maintanence correctly, but not sure why this is recomended.
