twin luff tracks
...in the foils are a common feature in all quality brand furlers such as harken, profurl, schaeffer, etc. Typically, a cruising foil will be more circular in shape to allow a tighter reef, while the racing foil will be more elliptical in shape to enhance aerodynamics. Both, however, will be equipped with twin grooves. Racers will be able to change headsails by hoisting the new sail before dropping the old. Cruisers will be able to rig twin headsails, winged out on each side, for comfortable downwind sailing. The drums on most of the high quality furling units can be removed fairly easily so the foil can be used by itself like a dedicated race boat.Just for clarification, the "foil" is the alloy extrusion part of the furling unit, the "drum" turns the foil.
