G
Gary
84 H31My battery monitor gave up and need to replace. Was thinking of a simple and inexpensive two battery bank set up of a double throw momentary switch (which I have on hand) wired to a stand alone digital monitor. Question.....Should this work OK running a single wire to each positive battery post and using a common ground? The switch is a single pole double (momentary) throw, so no way to switch the ground side. Any help appreciated.
