Whole lotta shakin' goin' on, revisited - Part 3...
We left you, still at anchor in Ft. Lauderdale's Lake Sylvia, reluctantly
preparing to come north to Vero Beach, to take a ball for the time we would
be gone to GA to do family stuff. It was reluctantly in that we'd fully
expected to get into the Keys, and maybe even to the Dry Tortugas. If you
read our prior, you know we took a month to sort out the stuff which had
taken place - thank you very much; we're blessed! - at anchor each time we
came in from the three times we moved the boat, and just ran out of time.
The winds would be on our nose if we didn't get under way, and we detest
"driving" (running the motor, even if we had the sails up, which we could
have done, but we'd have depended on successfully doing a great number of
tacks to avoid the Gulf Stream, which would NOT have been any fun in a
northerly, stiff, breeze), so, we made ready for our return.
On February 26th, there were very brisk winds in a favorable direction, so
we pulled up our anchor at 11AM. This time wasn't nearly the same as our
first two departures. It was STUCK, good, from all the wind and tide
changes. It did come up, but not without some persuasion. Once up, it was
like a giant shovel - hard packed "stuff" (I don't know whether I can call
it sand), complete with a lot of (big) clams) filled the scoop. My
salt-water washdown hose wasn't making a dent in this, so I lowered the
anchor into the water, thinking that our slow speed would have enough water
rushing by, as Lydia took us out to the ICW, to get it cleaned off.
Not so much! Up/down/up/down with the depth, and as Lydia turned the corner
for the ICW and picked up speed a little, lots more water. Eventually, it
did come clean, but it was plain to see that there was no way we were going
to drag in Lake Sylvia, as we thought we were doing in the beginning of our
time here!
Once again, this time more a matter of getting our anchor up, we waited on
the bridge. We'd not made the 11AM opening, of course, but for whatever
reason, I gather the 30-minute intervals aren't particularly hour-and-half
sensitive, as it seemed forever before the arms went down, and even more
before the bridge came up, as we played dodge-em, in the heavy outgoing tide
current, with the other traffic not constrained by height. None the less,
we did get through, and by 11:45 had our sails up. By noon, we were out of
the inlet.
This promised to be a rollicking good sail, as the winds were a bit nasty at
18-25 knots, which would make for 5-7' seas. We rolled out the genoa (we
started on the main only) at 12:15PM and settled into our initial course of
021° with 5-10 knots of apparent wind. Hm. Maybe the wind isn't so high as
the forecast, after all. In the relatively light winds, we were making 7+
knots both SOG (speed over ground) and TTW (through the water.) Maybe our
gauges are calibrated properly, after all!
As always in sailing, everything changes, so by 12:30, we'd turned upwind a
bit as the wind was dying and clocking; it was now only 6-9 knots apparent,
but we were entering the Gulf Stream, we presumed, as we were now making
8.2-9.1 knots, again both SOG and TTW on our new course of 025°, with the
wind on our starboard quarter at about 120°. Either that, or, again, we
were marveling at our new-found speeds.
The wind continued to clock, so we jibed and went to a beam reach. NOW the
winds WERE 15-25 knots, but we were rewarded with consistent speeds of over
10 knots, and a top of 12.7 (pix in the shakedown portion of the 2011-2012
refit gallery, if you click the link below). We were averaging 8.9 knots to
this point!
By 5:30, when the wind was expected to clock even further the forecasts were
saying 220° with seas at 6-8' and confused. We'd had a great sunny day,
along with all that wind, and our batteries, which had started at 80% of
capacity, were now up past 90% courtesy of our solar panels and wind
generator putting out about 100 AmpHours more than we were using with our
autopilot, chartplotter, instruments, refrigeration and whatever else was
running. With the sun down, we barely held our own :{))
6:30 saw the wind clock again, bringing the apparent wind to about 60° on
port, a close reach. Apparent winds were now 15-20 as we moved forward into
them at 9 knots on our course of 332°, still charging along toward our
destination.
8PM found us out of the Gulf Stream and fighting a 1.5-2 knot
counter-current in diminishing winds of only 12-16 knots, still on a 60°
apparent wind close reach heading of 315° - but we were STILL making 10
knots TTW and 8 knots SOG.
More changes, shortly the wind both backed, to make the apparent wind about
90°, a beam reach, and dropped, to only about 10 knots. Along with the drop
in the wind, the seas eased, which was nicer to ride in, but the
counter-current and wind drop meant that OUR speed also dropped, to 7.5-8.3
knots TTW, but only about 6 knots SOG. However, all was very well as we
flew along, and we had our hook in place, right out in front of the USCG
station, where we'd parked over 2 years ago after our 480-mile passage from
Ragged Island, at 9:30PM.
In the end, we covered 93 nautical miles in 10 hours, which counted the time
we were waiting for the bridge in Ft. Lauderdale, and accomplishing
anchorages with the attendant wandering around at relatively low speeds in
inlets and inland meanderings in both areas. Our trip calculator showed an
AVERAGE SOG of 8.7 knots, with which we are well pleased.
So, here we are again, in Ft. Pierce. A wedding and visits to children and
grandchildren beckons, and we have a mooring ball waiting for us in Vero
Beach, where a professional will check out Flying Pig for the next month, as
well as give us a ride in and back out when we return. However...
We have a Raymarine chartplotter which uses Navionics chips for the software
for the charts. Navionics' orientation for our chip is to cover only
southern FL while it's also covering all of Mexico, South America, and
points in between. The coverage extending North ends EXACTLY at the marina
where we did our refit. That means that we'll not have any electronic
charts at the helm for that portion of the trip, which is entirely in the
ICW (Intra-Coastal Waterway). We detest the ICW for a variety of reasons,
including that most of the time you have to be driving, not sailing, and, in
particular that's true for us with our 7' draft which, in the ICW, can
result in a grounding if you don't pay VERY close attention to detail.
I'm amused at us, because we came to chartplotters late; our norm was a gps
and a flat-paper chart to tell us where we were, and a compass to steer us,
in general. Yet, when faced with the possibility of navigating an inland
waterway without proper charts on the screen, we quail and shake in our
boots. Of course, those of you who know me well will know that I have not
just one redundancy for navigation (paper charts), but I'd not be
comfortable without at least one or more additional.
And thus it was that we used one of the three electronic charting programs I
have on my computer to navigate our way up the ICW to our mooring ball. Of
course, the trip was entirely uneventful, but I'm all for overpreparation as
compared to being unpleasantly surprised. We found the mooring field with
no difficulty.
The first ball to which we were directed seemed to be occupied, so we were
invited to take another, which we did. Fortunately, we arrived at nearly
full slack so didn't have a lot of current to deal with, and Lydia put me
right over the ball and its pendant. A reach down with the boat hook, a
quick snub to a cleat, and we have arrived. The usual alterations and
adjustments happened by lowering the dinghy, installing the outboard, and
taking a dock line forward to the mooring ball. Attaching it to the massive
stainless steel ring on which THEIR polypropylene rope was secured, I
loose-hung it as I cleated it off on the other side of the boat from the
mooring pendant. In the unlikely event of a failure of THEIR line, not ours
would take the load, with theirs failing before ours, and ours would secure.
This is a tidal "river" (really just the space in between the mainland and
the barrier island), so there is a change of direction at least twice a day.
Still, it's entirely safe, and we set about getting ready to take our
venerable, nay, ancient, thousand-dollar car, now 2 years from when we got
it for an expected 6 week stay, and pushing 298K miles, to and from both
North and South GA over the next 5 weeks.
As we were going to be gone from the boat for over a month, and uncertain as
to how things would do (recall our starter battery and questions about the
house battery from our launch day), we opened the refrigerator and freezer,
taking it all to the house where Lydia's mother is staying with the son of
her two best high school buddies, and turned off everything other than the
bilge pumps.
In the course of our in-and-out travels taking food and clothing in to
shore, I was amused to see that the freezer took 3 days to defrost, even
with both doors open. Obviously our insulation was doing the job we wanted!
Unfortunately, all that lovely new weatherstripping I had so lovingly put on
before we restarted the refrigerator in the yard, after our bottom job (we
have a keel cooler which needed to be free and open, and, while we were
painting, not hot, which it was during operation, as that's where the heat
removed from the system goes in ours), was the wrong stuff, allowing a great
deal of moisture-in-the-air to enter, necessitating that defrosting after
only 5 weeks. We'd also, later, see that what goes around comes around;
just as it takes a great long while to get warm, it would take a long time
to get cold again. But, I'm getting ahead of myself...
More shakedown, and the need to have the refrigeration turned off being
timely, I replaced the gasketing on the freezer door before we left. Just
like everything else which has needed attention since we got back in the
water, it's happened at a time which doesn't involve anxiety at sea.
The replacement gasketing on the freezer door appeared to be ideal, being
sort of "C" shaped (see pix in the shakedown section of the 2011-2012 refit
gallery by clicking the link below), and very flexible as well as "taller"
than the stuff I'd just put in, but had now torn out, as it made a VERY snug
seal, with the attendant squeaky noises (the thin, softest part contacting
the walls on the way down) for verification. The change also included my
mounting those gaskets on the doors, rather than the stops. So far, so
good.
So, we return from our trip, and, before we start provisioning, I also do
the refrigerator door in the same fashion. As I write this, 5 weeks out
from starting the system up (story below), it looks as though I'll have to
do some tweaking, but otherwise it's awesome. Only a cruiser could enjoy
what those on land take for granted, but we sure did/do!
Meanwhile, both doors mounted, now, I turn on the system. What's this???
The thermostats' digital readouts haven't moved for hours! After
defrosting, which includes my using my heat gun to melt the ice on the
evaporator plate, with the freezer at 70 or more degrees, it moves so fast
you can literally watch it. But, nothing.
Well, once again, if we're going to have a failure, it's happened at the
best possible time, with us at mooring and still endowed with that same car
which Lydia proclaims, daily (for more than 2 years now) will die
immediately, but hasn't, including the 3k or so miles we put on it in the
prior 5 weeks.
So, I get out my refrigeration gear and give it a shot of 134a, the
replacement for freon. Ah, it's moving! But, why not before? Surely it
must have lost its charge? Unless there was damage to the system, the only
possibility would be a seal (O-ring) failure. The last such instance, I
could tell by wiping my finger around the joint, feeling it to be slightly
oily. As refrigeration systems use oil as a lubricant, it was a good
indicator.
Now that there was some pressure and cooling going on, I did the same
(without pressure and gas moving in the system, the suspended oil wouldn't
come out of a failing seal), but came up empty. Perhaps it just needed that
little bit of oil and pressure to reseat the O-ring...
I have the proper tools to do an evacuation, and can, still, should it prove
necessary, but if a little is good, more is better, especially since the
system isn't cooling nearly as much as it should. Ok, another shot.
Same story, so another shot. No change, but I thought I'd better leave the
system alone for a while. The pressure line was hot, the return line was
cool, and the temps were coming down, SLOOOOOWLY.
But, then, they stopped. And, the temps started up, slowly. OY! Back into
the engine room again, I'm embarrassed to say that I determine that I've
MASSIVELY overcharged the system. The return line has ice on it all the way
back to the joint of which I was suspicious before!
The standard for our system is to have the line exiting the bulkhead be no
more than cold, and certainly not iced. So, bit by bit, I took out charge,
and, like the dawn of the end of the ice age, the ice retreated. When it
got to the point (over several days - I didn't do anything "large" or
quickly in order not to have to add 134a again) that the line out of the
bulkhead was cool, I waited.
Sure enough, SLOOOWLY the temps came down, and then, over the next couple of
days, it inched its way down to our design temperatures. And, it's been
fine ever since. Ever the headscratcher, I finally deduced that, just as it
took days for the ice to melt during the "organic" (no heat assistance)
defrosting, that having been due to the "cold flywheel" of 6" of foam
insulation slowly absorbing heat, that same insulation required that long to
get cold again. Once the box is chilled, the contents can stay like that
with very little extra effort at removing heat.
So, still preparing for our East coast tour when we leave Vero Beach, our
new chartplotter chip arrives. We install it just prior to a day trip down
to Ft. Pierce and back. WHAT!!! No info, just a block representation of
where we are!!! I do a check, and it shows as a "Platinum" chart, whereas
the box, and my order, was for a "Gold" chart. Maybe that's the problem;
ours is a relatively older (in electronics' terms) chartplotter, and the
software doesn't know what to do with the chart. That had been the case in
our other chart, but a firmware upgrade took care of that issue.
Unfortunately, we knew that we had the last update issued, so this chip
wouldn't work.
Oh, well, another anchored problem to solve. When we get back from the
daycruise, we'll contact Navionics (the chart maker, the ONLY one our
plotter supports, dangit!) and get an exchange. In the meantime, out come
the paper charts, our computer charts, and eyeball model 1.0, which will be
fine for our meander down the ICW, and we make ready to depart, which
includes our motoring slowly ahead to take the tension off our lines. By
the time that's done, and I get ready for maneuvering among the moored boats
to get to the channel, I notice that the chartplotter, still on all this
time, has suddenly gotten smarter, and all the usual info and detail is
there in all its glory.
I presume that it was a matter of all of the charts loading into the
plotter's memory, and not available in detail when first initiated, because
I can think of no other reason for the behavior. None the less, it works,
and there's another shakedown squawklist item which can be marked off.
All that remains is for us to finish provisioning, decide whether or not to
take the dreaded "ditch" (ICW, with all its motoring), or to go outside (in
the ocean, where there a very few inlets we can use in case of trouble for
an awful lot of miles), in a boat we've not yet, at least in my mind,
thoroughly shaken down, and leave.
So, we'll do that, and catch you next time. Until then, Stay Tuned!
L8R
Skip
Morgan 461 #2
SV Flying Pig KI4MPC
See our galleries at www.justpickone.org/skip/gallery !
Follow us at http://groups.yahoo.com/group/TheFlyingPigLog
and/or http://groups.google.com/group/flyingpiglog
When a man comes to like a sea life, he is not fit to live on land.
- Dr. Samuel Johnson
time here!
the inlet.
this point!
destination.
no difficulty.
bilge pumps.
good.
prior 5 weeks.
indicator.
wouldn't work.
L8R
Skip
Morgan 461 #2
