Whole list of H23 winter projects I could use advice on
Sep 28, 2014
25
Hunter 23 South River, MD
Looking for advice, I apologize in advance for the novel,
I’m hoping you all can help me out with a the long list of winter projects I’m working on while my boat is out of the water (break out another thousand right). I’m looking to turn my boat into one I’m comfortable taking around the bay on multi day trips, and with that, it needs a lot of work.
The first issue I have to fix is an anchor light/VHF radio. I’ve purchased a light from west marine, but now have to figure out how/where to mount it on the mast head? Any ideas? Another thing that’s going to complicate this is the VHF radio I just purchased. My current one is a handheld, and its life is limited by its small battery. Growing up sailing in S. Florida I like the additional power/range the mast mounted radio antenna provides. I’ve purchased the radio and whip antenna, but am not sure how to get them all on top of the mast/wired without interfering with my wind vane (mast is down right now). Currently I have two wires that go up my mast and power my steaming light (which doesn’t work either right now… another project I’m working). Another issue I’m concerned with is, will the coax cable cause a lot of noise bouncing around the inside of my mast? How do I mute it? Lastly, how do I run the wires? The interior of my cabin is covered in a fabric and I’m not sure where the wires are currently routed. I’m also worried that if I pull the fabric back I won’t be able to get it to stick again?
My next project is running my halyards back to the cockpit, and installing a downhaul for the jib (I don’t want to go with the roller furler). I’ve seen a lot of good posts/pictures of running both halyards out of one side of the mast and back to the cockpit, but how would you all route the downhaul? I’m thinking all I need is one standing block on the bow, but I’m not really sure where to mount it. Real estate is limited with the anchor locker so far forward….
Also, my wife is insisting that I have some sort of lifeline on the stern before her or my daughter get aboard (kiddo just turned 2 this past weekend). I have a vest and tether for my daughter, but my wife is still concerned, and I guess I can understand that. Extra equipment to keep people on board is probably a good thing (plus it could give me a spot to mount a GRILL:dance:). I’ve seen many other Hunter 23 owners with Pics of stern pulpits, but haven’t seen where they found them/had them made. I’m hoping to fund/rig something that won’t get in the way of my swim latter too much (or that I can clip lose). Any ideas or recommendations?
Fourth question (I appreciate your patience here). My Hunter 23 is an 85 with the wing keel and extendable centerboard. Before splashing the boat the first time, and at the recommendation of several sailors at my marina, I removed the line that locks the centerboard in the down position. They said this was very important for sailing the upper Chesapeake because of how shallow the water is throughout most of the rivers. I did however rig a couple of zinc weights to it, so when in open water, if not tied up, gravity would assist in lowering it. Now, after a season of sailing however, I’m wondering what the keel actually does when I’m close hauled and trying to point? Will it remain down with a couple of dinky zinc weights that make it just barely heavy enough to sink? Should I reinstall the second line? I don’t have a depth sounder, but I do pay attention to my charts and lock the centerboard up when close to shallow areas. I haven't had any issues, but I’m just thinking I may point better if I can ensure that the keel down and cleated. Thoughts?
Lastly, I’ve noticed I have a few small rust spots on my keel. I asked the broker I bought the boat from and asked him for advice (after reading horror stories here about resealing keels) and he told me “All iron keels will rust a little bit, don’t worry about it too much, just scrape, sand repaint and go sailing!”….What do you all think?
I appreciate any input on any of the topics I’ve listed.
Dan Fleig
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
Hi Dan,
Give me a call if you'd like to discuss running your halyards and downhaul aft.
Toll Free 877-932-7245 x116, Mon-Fri, 9-4 Pacific
Sep 28, 2014
25
Thanks Dave, I'll try to give you a call when I get out of work today
Sep 28, 2014
25
All,
Here are a few pictures of the base of my mast as it sits now in my yard. You'll notice that now, there are no blocks at the base of the mast, so I'm looking for recommendations on that.
I've also posted a picture of the bow pulpit, you'll see there's scarce room up there. However, there is a small metal bar (not actually sure what it's for) that I could maybe attach a block to.
As far as the halyards, I'm considering leaving the Jib on port and the Main on Starboard as they are now. Figure that way I can run the main back to a winch and a cam cleat. (I've had other people recommend clutch cleats, like the spinlock, but for the price, I'm not sure I need all of that for a 23' boat), then I can run the jib down the other side, and have the down haul right next to it. I don't think I need a winch for the jib, so a double cam cleat should do the trick.
I'd post more pics of the interior of the boat for my other questions, but I'm going to have to wait for the 3" of snow on top to melt first.
-na -NA Anywhere USA
/Dan;
I see you have one of the original few 23's with the wing/centerboard version of that boat. They were made briefly until Hunter went with a solid wing keel about the time I came on board as a dealer with my first boat being a 23 wing keel. Your friends are correct to let the lock down line for the centerboard to remain loose unless you are in deeper waters and when you come in, just remember to loosen up that line. a
Look at later models and note the location of the deck line organizer turning block for better lack of words that would lie flat on the deck and usually two or three blocks and location of winches and so on. Generally, Hunter use to put in aluminum plates encapsulated in the fiberglass for attachement of hardware which you could drill and tap. Before drilling a large hole, drill a small hole to see if any metal shavings come out.
Also, I did not see a photo of the actual mast step that the mast sat on. That will help tremendously as to what blocks could be added for turning the halyards and down haul at that point. Either you have a Z Spar or Kenyon Isomat mast. No problem as parts are still attainable for either mast either thru the forum store or I can tell you after going thru the forum store in the event they do not have them.
That broker gave you very bad advice on that keel of yours. Once I visited a brokerage that did not last long and that broker said in your case to fill in with bondo and go until I told him the proper way to repair and I indentified myself at which time I was invited to leave. Here is what I would do. Clean out the area and brush the metal portion until all debri and rust is removed. Then spray a metal primer containing zinc chromate on the spot to stop the metal from rusting and fill in with a two part epoxy in warmer weather. Do not use the putty sticks as I have seen that fall out from time to time but rather a slower cure two part epoxy. I know it is expensive but the best and 24 hour is one called Water Tite and it never failed on me in my years as a dealer. Then apply barrier coats to the spot and paint.
My email is davecondon@mindspring.com if you need further help.
Sep 28, 2014
25
Appreciate the insight! Hopefully the snow will melt next week and I can take the tarp off of the cabin. Then I'll post some pics of the mast step, cabin top and mast brand.
I figured the brokers advice didn't sound right to me. You said use a metal brush to clean it out, I was actually thinking of using a sand blaster. Am I risking damaging anything that way?
Yes, the rest of the boat and you unless you have proper protection and know how to confine the sand. Do it on a no wind an clear day with the area devoid of cars, structures and so on. For the small areas, do you have a dremel?
Sep 28, 2014
25
I don't have a dremel, but do have a pneumatic cutting tool/grinder wheel. I've seen wire brush attachments for it. I had just noticed small sand boasters for sale at Harbor Freight and figured that may be easier to get into small pits. I don't really know anything about using one, but figured it could be a nice tool to own. You think it's more trouble than it's worth?
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
For some reason I can't see your photos now, tho I did a day or two ago.
I have the 23 wiht wing keel and did redo the keel. Mine had a lot of old paint and thick rust when I bought it, so I used an angle grinder with a grinding wheel for some parts and wire brushes for others. I tried the POR "paint" - OK, not great, but easier than epoxy. It lasted a few years with minor rust bubbling, and is still servicebale but not great. If you are willing to do the work, and want what would likely be a longer lasting job, I'd do what Dave suggested.
My mast has an anchor light screwed directly onto the top of the mast crane. You could not do that with the windvane you have. I have a Spar Fly I bought for mine, which comes with two mounts; one is a plate that would mount to the top of the mast fitting, the other is a clip that mounts to the mast side right at the top, which I used. The shaft is thus offset (if I recall mine is on the mast's rear) and the vane is above the top of the lamp. I assume there are similar fittings for antennae (which I don't have being on a lake). There may also be fittings that allow you to mount a new lamp to the side of the mast in a similar way. The Spar Fly is ot too costly (maybe $25) so it may be worth it to discard your Windex style vane. I would attach a messenger line to one of the (ideally unused) mast wires and pull it through, then use that messenger to pull the old and new wires back through. Obviously first test the connectivity of all leads of any old wires you want to reuse, in case broken, so you could pull a new one if needed and avoid rework. I lack coax, but don't see why it would be noisier than the existing 12 v leads. I have had to peel back the "mouse fur" type fabric to get at various fittings and to repair a rotted chain plate bulkhead, and found that contact cement worked OK to glue it back.
I lack a centerboard, but the rudder is a sort of kick-up style. I don't know the centerboard on the original 23 at all - is the locking line tied to a cleat? If so, you may consider (if it can be mounted) a jam or cam cleat instead, given that only gravity seems to work to hold it down now. My H23 rudder has this, and I once dragged on an unmarked rock (well, the whole lake is unmarked - no charts like the Bay) and while the tip of the rudder was gouged a bit, the line's outer cover stripped and the rudder basically kicked up. That may be protective enough for the muddy bottom typical for the Chesapeake. Seems to me it'd sail better if the board is in its proper down position most of the time.
At one time there use to be a cam cleat that would kick up or release in the event of over tension but for the life of me I cannot put my finger back on it.
Dan;
I would suggest that you start on or two projects, finish them and then go on to the next. See what is the most important first and of course leaks being a priority. I have found too often if you start on too many, you will become overwhelmed and could make mistakes and possibly loose items. I would table many making a list of what to do first that are important to the least important. I saw this happening and folks would become frustrated when they say they won't. Pritorize first the most important.
Jul 13, 2010
1,100
Precision 23 Perry Hall,Baltimore County
I redid my rudder last year, found a quick release cam cleat to mount on the tiller at
Annapolis Performance Supply I believe it was. Just went to the boat folder, can`t find receipt but I`m pretty sure that`s where I got it.
ebsail
Nov 28, 2010
241
O day 25 Nyack. New York
Re: the VHF. On my Oday 25, I mounted my VHF antenna on a 8' vertical piece of PVC pipe (about 5/8") from Home Depot and strapped it, with 2 hose clamps, to a vertical of my stern pulpit. Eliminated running wires through the cabin, and having to have disconnect plugs when hauling the boat. I just leave the pole up when I take the mast down. Or if necessary, the hose clamps can come off and the pole comes down without disconnecting anything.
The coaxial is inside the pipe and runs into the boat through a vent hole in the stern. No noise, no connectors to corrode, gives a 25 watt transmitter at least a 10 mile range (line of sight). You won't need more than this on the Chesapeake Actual height above the water is 3' freeboard plus 8' pole plus 18" of antenna.
Aug 22, 2011
1,113
Cable slap inside a mast can be tamed. You can use 3 electrical zip ties pulled tight onto the cable bundle every 12 inches or so along the entire length. The uncut legs of the zip ties make for standoffs inside the mast. That's what we've done - nice and quiet and cheap fix but the cable has to be pulled from mast to get it done. Other people have use lengths of pipe insulation foam on the cable bundle also.
Can't see all of the bow in your photo. A block for the downhaul doesn't' take up much space and needn't be overkill. It just needs to be very near the tack of the sail so that it runs fair. Ours just runs down the side deck from the forward block to a cleat. Other folks put station mounted blocks or stanchion mounted fair-leads all the way back.
The railings around a cockpit are called "pushpit" as opposed to "pulpit" that are on the bow.
Good luck with your projects - damn snow...
Oct 3, 2006
1,041
Hunter 29.5 Delaware city
Hi Dan,
I owned a centerboard H23 for many years (and still miss it!) . It used to be slipped at Locust Point in the Elk River. My stern pulpit was made of light gauge stainless conduit with 4 bends in it, it a pretty simple project. Two 90 bends at the aft corners, and ~12" after that bend, a 45 down towards the deck, plus two vertical posts and some standard hardware.
My windex was mounted on a short aluminum strap that placed it about 8" behind the masthead
As far as the centerboard. It is extremely buoyant! a few zinc weights will do nothing. I used a fairly stretchy climbers-type line for the hold down, with a 4:1 mechanical advantage - you will find it very difficult to get down with less than that. I used it as a depth sounder many times and never noticed any damage or loss of functionality.
As a side note, the best feature of that swinging board is balancing the boat. Out on lake Ontario, sometimes it would get quite windy. On main alone, the boat balances quite well with less helm having the board up, and "tracks" very well. Board down? it'll spin on a dime and well balanced with both sails up.
Sep 28, 2014
25
Brian,
Great info! Do you have pics of your stern pulpit? Did you make the aluminum strap to relocate the windex or just jury rig something?
Dan
Sep 28, 2014
25
That is really cool! Wind on the antenna didn't make it hard to read? Mounted on the bottom I guess.
Ward H
Nov 7, 2011
3,843
Dan, for your jib downhaul, you should look at attaching a block to the same hardware where your forestay attaches. It would save you from creating more deck penetrations for the stand up block.
When I spoke to Garhauer about their hardware recommendations for running my halyard back to the cockpit on my 25, they suggested I could use a Harken 150 cam cleat.
I would think you could use cam cleats for the lines you run aft instead of rope clutches. I would save the dollars and skip the winch also. Do you really need it? Do you have a reef line? If your running your main halyard back you might want to run whatever you need to reef back also.
Please remember I suggest these things not knowing your specific boat. Crazy Dave knows best here.
I do suggest you follow his recommendation to make a list of your projects and prioritize them. Life Safety, Crew Comfort, Boat Preservation, Sailing Ability were the categories I used. I also separated the list into before launch and after launch since I was keeping it in a slip so some projects had to be completed before launch or wait until next year.
That list let me plan and make a budget. After my first season of sailing my priorities changed and I rearranged the list. Now I finished my second full season a lot of the items I thought I needed dropped down to the bottom of the list.
#1 priority will be to keep your wife happy and your daughter safe.
Have fun!
