- Oct 22, 2014
- 24,753
I have a new to me Cal 35 Cruiser built in 1974. Like many of you I am discovering things done by Previous Owners and wondering, "What were they thinking?" I left the boat for a couple of weeks after working on the engine. (Never ending projects of mercy trying to solve past non maintenance issues). Since I was to be gone for 3 weeks I closed all through hulls. Felt like a reasonable course of action. 'Keep all water outside the boat while not there'.
We had a rainstorm forecast in the area the boat is moored, and my gut was uncomfortable about the boat. I told my wife I was heading up to the boat for the weekend. She said Go! Your just restless here. I thought it would be a good time to start the prep work on installing the heater and other tasks.
Got to the boat an the sink was full of water. There was water on the counter top and in the pantry that is behind the counter. What could of happened. Is there a leak from the deck above the counter? Are the chain plates somehow dripping? Is the deck seam failing? No. None of the above. Some fool plumbed the drain from the cockpit into the sink drain line. So when the rain hit, the water from outside the boat flowed inside. With the through hull shut to keep water from filling the boat in my absence, the cockpit water backed up into the sink and made a mess.
Have any of you plumbed cockpit drain lines? Do you use PVC or tubing?
Thanks for your help.
John S/V Hadley
Sailing the Pacific Northwest.
John S/V Hadley
