Who makes DIESEL fuel tanks (polyethylene)?
abe
Jan 2, 2007
736
- - channel islands
Who makes them for Hunter, Catalina? I want to add additional tank on my H36....all the tanks I see are for holding/gasoline/water. Where are the diesel tanks? thanks abe
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Check with Ronco. Great to do business with. Polyethylene works fine for diesel as well as gasoline or water. http://www.ronco-plastics.com
abe
Jan 2, 2007
736
- - channel islands
Ronco, can they be used for diesel? Are they cross
cross linked polyethylene? I remember reading something about only using Ronco for water/holding.
Jed Smith
Plastic fuel tank
Try Tempo also. Note that with diesel and cross-linked polyethylene there will be a small bit of expansion the first time fuel is put into the tank (~3%). Just put a new one in my Cal 29, works like a charm although I miss the sight glass on the old tank but not the duct tape :)
Dec 2, 1997
9,011
- - LIttle Rock
Ronco makes only water and waste tanks
They're made of linear poly, which cannot be used for fuel holding. Plastic fuel tanks must be made from cross linked poly and--unlike metal tanks--must also be CG certified as fuel tanks. Any plastic fuel tank that can hold gasoline can also hold diesel.
