S. Hockey
I'm getting more white smoke on a cold start than I used to get, it clears up within a minute. I have also noticed that my electric fuel pump starts realy fast then slows to pulsing but does not shut off completly.I disconnected the fuel line at the filter located on the engine and no fuel came out. I inserted a gauge on the line and got about 5psi and still the pump did not shut off completly.I spoke to mechanics and some say that the cause is the injectors, others air in the fuel line(problem with electric fuel pump).The M 25XP engine runs fine.Questions.1. Is the electric fuel pump supposed to shut off completly once the system is pressurized or does it still pulse a bit?2. Where can one buy a replacement pump?3. Should there be fuel in the fuel line between the electric pump and the filter on the engine after the engine has been off for a few hours, or does the fuel flow back thru the pump?4. Could the injectors be leaking a bit?If others experienced this problem I would appreciate their response.Thankssa-hockey@telus.net
