White Laminate for Interior Plywood
GuyT
May 8, 2007
406
Hunter 34 South Amboy, NJ
I have an 85 Hunter 34 and the thin white laminate attached to the interior plywood came off (delaminated) in several spots and looks pretty bad. The original laminate is very thin (I would guess less than 0.030") and the adhesive became unglued and then the laminate basically cracked off in various sizes. I am looking for suggestions about what white laminate could be used and what adhesives I should use to attach the laminate. The local Marina sells a fabric/vinyl style but I was hoping the Forum could help out with some ideas.
GuyT
May 8, 2007
406
Dec 3, 2003
2,101
Hunter Legend 37 Portsmouth, RI
I Used PHEN-O-SEAL...
...to replace/paint the area I have in the shower. It was peeling from the plywood, so I scraped it, sanded it and then spread the sealer with a squeegee-type of spreader. I then sealed the water-intrusion areas with a silicone sealer. It has been fine for a few years and has never yellowed. Only the silicone sealer has discolored. It comes in a tube (like silicone) but is used as a sealer/grout for tile.
Dec 3, 2003
2,101
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
GuyT, you didn't say which areas are involved but
I do know that any laminate (Formica-type stuff) would work if you can find a color+texture match. The job will be a pain cause you have to remove all the old and apply the new to a properly prepped surface with a good contact cement. Epoxy 'might' work but I would talk with an epoxy manufacturer before I tried that.
Clark
Jun 30, 2004
886
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Home Depot/Lowes
has 4 x 8 sheets of plastic that I am going to use for a headliner. It is fairly thin, but more than .30. Contact cement works pretty good on it, or you can use liquid nail for shower/tub enclosures. Much less expensive than what you can get at a marine store. Available in different textures, but mostly the color is limited to white.
May 11, 2005
3,431
Home Depot/Lowes
Dec 2, 1999
15,184
Don't think that it is formica!
I do not think that you are dealing with formica over plywood. I believe that this is a melamine product. This is what we had in our head area on our H'31. The product may not have been the best solution for an area that was damp and closed in. You may be able to peel off the stuff and then apply a formica type product over what you have.
Dec 2, 1999
15,184
Ross
Jun 15, 2004
14,693
Any of the high pressure laminates
that can be bonded with contact adhesives need a fairly smoth surface for bonding and will show all of the irregularities of the subsrate. Contact adhesives are just that, when the two coated surfaces touch they stick. Test fit all of your pieces before you apply any adhesive and plan your procedure very carefully.
Ross
Jun 15, 2004
14,693
Ross
Jun 15, 2004
14,693
Make patterns with large pieces of wrapping
paper first. There are special shears for cutting laminate. Cut the piece to the pattern but just a little oversize. Test fit and trim until you are satisfied with the fit. After that you need to plan very carefully as to how you will place it into position.
Ross
Jun 15, 2004
14,693
Jul 1, 1998
3,062
Original Was Melamine
Steve Dion is correct - the original finish is Melamine. It is available in various surface textures. For what it's worth, several years ago I came across a plywood laminating firm in Seattle (Ballard) that could custom laminate a Melamine sheet onto the plywood but it ran about $200/single sheet. I doubt they would sell just the Melamine sheet by its self because they are more into volume but, if you wanted to use the same material there may be a firm that could.
Jul 1, 1998
3,062
May 7, 2004
51
- - Fern Ridge Eugene OR
2nd the laminate
Our counter tops and some other surfaces were that same product. I took a heat gun and removed all of it. Then fitted WilsonArt laminate and you can just glue it on with contact cement. Looks much better and holds up much better. You can upgrade colors as well. They have some that even resemble granite if you are wanting a change. Rob Morton
