Whisker poles?
Aug 7, 2015
124
Oday 34 previous, O’Day 40 current Annapolis
Cold as hell here in MD & time to dawdle in obscurities; do any of you 34-35' types use a whisker pole? If so can you recommend a general length?
thanks,
Lou
Oct 25, 2011
576
Island Packet IP31 Lake St. Louis, Montreal
Lou the rule of thumb for spinnaker poles was for the length to be equal to the J measurement (Tack fitting to mast base). The correct length for the whisker pole will depend on what sail is being poled out so an adjustable pole will be of most use.
Cheers
matt
Likes: Dave Groshong
Nov 26, 2012
1,654
C&C 40-2 Berkeley
It should be the length of the foot of the sail that you are using. That is why whisker poles are adjustable. If you got your 110 up in then its that length. If you are going with the 155 then you make it longer.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
Minimum length is J=14, but I would check it, adjustable to the length of the foot of the sail.
Oct 7, 2008
380
Oday Oday 35 Chesapeake Bay
Mine is adjustable and works well with both the geny and spinnaker.
