sorry-
sorry i guess i lost it. to use the pole with the assm, you will need the fitting Ed directed you to,( good find ed) and a track to mount that on. you should have a pole lift, and a pole downhaul, these keep the pole in place while you set. if your going to race with it, the pole can not exceed you j-demension or you will recieve an additional penalty on your rating.In most places you can mark the pole at that length and just not extend it any further.the assm sail is tall if its the right size for your boat so the pole will have to be set very low, depending on how tight you want the luff. so be careful not to put to long a bridle on the bottom of the pole. This provides a way to set the pole in place and hold it there before you set the sail other wise the pole is flopping out of control.Dont know if we answered the question or not.hope so.
