Forespar mounts
As Tom Long mentioned already mentioned, the Forespar rubber clamps are a good chocie.I too have a Forespar 8-14' whisker pole and have it mounted horizontially just above the deck, on the rail between two stanchions (sp), using two matching Forespar hard rubber clamps.I race a lot and this arrangement works extremely well. It's quick, easy and safew removing the pole as well as replacing it when finished. Nicest part is that the pole is always out of the way, yet close at hand.Rodgers/v Attitude AdjustmentIMHO, that pole should NOT be mounted on the front of the mast. It'll be much harder to work with there, tend to be in the way when hoisting you AYSO, and may be a source of otherwise avoidable sail chaff when tacking.
