Whisker Pole Size for Hunter 37C
Aug 27, 2025
21
Hunter 37C Bainbridge Island
As I continue to refit my Hunter 37C, I am now devoting some thinking to a whisker pole for poling out the Yankee headsail. Based on a lot of reading, I’m going for a fixed/spinnaker-type pole made of aluminum—not adjustable length. I prefer the lack of moving parts, lighter weight, and durability of a fixed pole, and I’m thinking of going with 3” tube. Presently I have no mast track set-up for the pole, and I have an asym for lighter air downwind sailing. So I’m primarily looking to use the pole for the Yankee. I will be adding a track for the mast end of the whisker pole.
Most recommend a whisker pole length roughly equivalent to the foot length of your headsail. My headsail is a Yankee (and I’m staying with the Yankee and staysail plan), so the foot length is 16’8”. Because of the high cut clew of the Yankee, however, the LP (luff perpendicular) measurement is only 12’11”.
Should a fixed pole—I’m not going to be changing headsails—be sized for LP on a Yankee headsail instead of the foot length? I’m hoping it can, as on deck storage and pole deployment get a little easier at 12’11” than at 16’8”.
As always, your thoughts are appreciated.
I would use the LP measurement for a yankee rather than the foot. The foot length is artificially inflated by being at a steep angle. Your LP will be a better indicator of how far outboard the clew really needs to go. Many PHRF fleets also limit the pole to J, regardless of foot length.
You’ll also need to make sure the track goes up pretty high. With a more traditionally cut sail the clew is much lower - mine is about boom height. But with a yankee the clew is way up high, and the pole needs to be horizontal, so it also needs to go way up. If the clew is above head height you might need a topping lift to pull the car high enough, not just a pin-stop car.
Likes: shemandr
Aug 27, 2025
21
Thank you for your input! I asked my sailmaker who also suggested the LP length is appropriate for sizing the whisker pole for the Yankee.
Luckily I found a 12 foot spinnaker pole with 3” diameter tubing on Craigslist. Good shape and the jaws still work great because it came from a freshwater boat. I’ll start messing about with that and the unfurled Yankee to determine the proper height of the mast attachment and rigging the guy lines.
