78' Cat with hank-on foresails. I recently purchased a 7-14 whisker and am having issues with deployment. I would like to use this with my 150% Genoa but find that with full deployment, the pole will not work forward of the running rigging, seems too long. Should I run the pole between the standing rigging? Seems dangerous and possibly destructive.
Also, it is not rigged with topping life, foreguy or afterguy. Is this totally necessary?
What is the best way to extend the pole for deployment and then retrieve it? The buttons that lock the pole into place have no automatic release, so once locked into extension, the locking buttons are seven feet off the deck. I have to unhoook the whisker at the mast and bring the whole pole in manually before shortening it again.
Most everything I see online uses a roller furling setup which appears much easier. Alas, I am old-school (and short on boat-units).
Tried to deploy coming back into MB from Oceanside this past weekend and ended up with a lot of headsail in my face as my dad tried to keep us pointed wing-on wing.
Any advice?
Thanks!
Any advice?
Thanks!
