A “CQR” is a hinged shank Plow type anchor, manufactured by Lewmar (Simpson-Lawrence).“Kingston” is a manufacturer of anchors, both Plow and Lightweight (Danforth) style.The Kingston “Quikset” is a plow anchor, more similar to Lewmar’s “Delta”, than to the “CQR”.
The CQR is drop forged including the hinge, the Kingston plow is cast as are oher CQR copies. A drop forged steel object has a great deal more strength and resilience than a casting - the reason they forge crank shafts etc.The Kingston Quickset, as Gord has indicated is a non pivoting anchor similar to the Delta, and is welded steel.
I just did a google on Kingston anchors and the danforth sytle and delta style were not what I saw but a CQR look alike. The link Malcolm provided was helpful in describing the CQR construction material and method.My boat came with a Bruce and a Danforth, but I am thinking of acquiring a CQR; however, some one mentioned they were somewhat of a challenge to mount off an anchor roller, with the head of the anchor moving around. Any comments on this?
I have had no problems with the CQR and anchor roller on two boats. However this is a function of the roller size, the anchor size and the design of the boat. It does not move around - I use a heavy shock cord over the shank and a short Caribiner from the shackle to a cleat to keep it from dropping. Some comments:- It is good for the anchor roller to extend out away from the stem of the boat so that you have clearance for the tip (many anchors have the same problem - eg Delta, Bruce).- the width of the roller should be close to wide enough that the wide part of the swivel on the anchor either passes over it (or at the least jams into it as in my current boat).The anchor works quite well in most bottoms including weeds (that is its beauty). However, studies have indicated that in weedy bottoms it is better if it is 25lbs or heavier. If you have a larger boat this should be no problem. However if you have a 23 footer you may want to think about alternatives.
Have a 35# CQR mounted on Bow of a Hunter 34. I drilled two holes through the Bow roller assembly and the web of the shank of the CQR. I have two quick release pins which hold the anchor from bouncing up and down and or off the boat in heavy seas. I am certain that this voided any warrenty but if the anchor breaks because of two 1/4 inch holes drilled in the web of the anchor shank I will have more to worry about than a $400 replacement warrenty. I am afraid that shock cords break and thus the pin solution.Fair winds, following seas and quiet anchorages.Charlie
