While sailing & Eng. is off, Should Eng. be in R,N
Jim
While sailing and engine is off, should the engine be in gear or in neutral ? Thanks, Jim
Dec 2, 1999
15,184
Depends on who you listen to.
Jim: I think that the concensus was that if the prop is turning then you should shift it into reverse. If the prop is NOT turning do whatever you want. Check out the archives. This has only been discussed about 20-30 times in the last few years.
Bob Greenfield
Reverse
We leave ours in reverse on the advice of the salesperson. Apparently the prop turns when in neutral.
Bob
Reverse It Is
Went to a Yanmar sponsored diesel class and that was their recommendation.
A
Andy
Depends on your system
As Steve mentions, there is a lot of previous discussion you will find in the archives and the answer may be there. I spoke to the sales person at the marina as they use a H 27 of the same vintage as our boat as a training vessel. He recommended using reverse. HOWEVER, like others I spoke with he said, IT DEPENDS on your transmission. Some transmissions can freewheel with no problem, others, as with serious racing boats require particular attention. SO, it would be prudent, in my opinion, to seek our an "expert" on your particular transmission and follow their recommendation. Andy s/v Baroque
G
Gail Moorehead
behind the strut
I called Yanmar and for my 376 he said. If the engine is not running the transmission is not being properly lubricated, use reverse. I do something that I believe may reduce drag. At a slow speed my wife puts the transmission in neutral I then position the 2 blade propellor so that the blades are vertical behind the strut she then goes to reverse. It may or may not reduce drag but it might.
Tim Schaaf
wear
One thing is for SURE...leaving your engine in neutral and letting it freewheel will add a lot of wear on your packing gland and your cutless bearing, regardless of whether or not it hurts the transmission. Naval architects also have a complicated explanation of how the spinning prop actually ADDS drage, relative to the stationary one.
Dakota Jim Russell
Get a feathering prop and solve the problem <nm>
