Which sail stop to use for O'Day 25?
Jul 7, 2004
8,536
Hunter 30T Cheney, KS
It should look like your mainsail slugs. My Mac used the first one.
I eventually closed my slot and installed a mastgate
https://www.mastgates.com/
My Hunter has a gate/cover that screws on. Not automatic like the MastGate. The Gate would be handier on a trailersailer I think
Likes: jwing
Mar 2, 2019
672
Oday 25 Milwaukee
The first one will fit . The stop needs to be positioned above the feed slot . A small piece of alumimum can be easily used to make a mast gate .
Sep 24, 2018
4,535
Catalina 30 MKIII Chicago
Thanks Timm. I'll make a mast gate at some point. Right now I just want something to keep the sail from falling out of the mast
Jul 7, 2004
8,536
But 2. It's inevitable that the first one will loosen and fall into the water! :cuss:
Another good reason for a gate.
Sep 24, 2018
4,535
My efforts need to be focused on getting this boat into the water and $50 for a mast gate is a bit much for something I can make for $5. In the meantime the sailstop is a good, cheap alternative. If I have time I'll throw some blue locktite on the threads and a ring terminal with line crimped on to keep it from going overboard
Sep 24, 2018
4,535
I went to install the stop over the weekend. A previous owner had already installed a mast gate. Also found the round style of stop does not fit the O'Day's mast. I'm guessing the larger square stop would be the right one but dont quote me. Just thought I'd follow up with some accurate info
