Which motor for max hull speed. Hunter 25
KennyH
Apr 10, 2007
148
Hunter 25 Elizabeth City NC
My original 1979 evinrude 9.9 long shaft died and parts to fix could not be found. I replaced it temp with a 6hp short shaft. I would like to find a new motor that would run 6 knots in most conditions. Do I need a 9.9,8 or less. My hull is need of a bottom job and the 6hp will only do 5 knots which is fine for now. Just wonder what people are using and what max speed they get out of it. Thanks.:confused:
Jun 6, 2006
6,990
max hull speed is:
1.25 * square root of water line length
for you case that would be 6.25ish
the 1.25 constant is a hull shape number. "finer" hulls have larger (1.3) and "fatter" hulls have lower (1.1) numbers.
All bets are off if you surf down big waves BTW
Nov 8, 2010
11,386
I would care too much about maxing your hull speed. I'd worry more about having enough beans to keep you off a lee shore in a crappy seastate and a blow.
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
basic rule of thumb for engine size is 2hp per 1000lbs of displacement. that should normally be enough power for hull speed even in 1-2 foot seas, the more wetted surface (full keel) or heavier seas you expect to be in, the more power you'll need.
KennyH
Apr 10, 2007
148
Thanks to all and mostly fourPoints I have settled on a Sailmaster 9.9. It has a 25 inch shaft to keep the shaft in the water and should have the power for hull speed of 6.25 knots. I will let you know how it goes after it is installed. It is electric start so I am looking forward to push button starts. The current 6hp only gives me 5 knots at full power.
KennyH
Apr 10, 2007
148
A follow up on 9.9 sailmaster
Love the electric start. Love the charging it does to my batteries. Has plenty of power. I am seeing close to 6 knots and I need a bottom job bad as it has been 5 years on my current bottom job. I think it is the perfect power and shaft length for the boat.:dance:
Dec 8, 2011
68
Hunter 25 Chicago
I got a lot of push-back from people not liking what I did....but I recently put a 15HP Tohatsu long-shaft on my 78' hunter 25. I love it, great power, plenty of torque, and a great charging system. I used the garelick 15" travel mount and it works great, I have not had one issue.
Erieau
Apr 3, 2009
209
Oday 25 Erieau
Electric start = awesome.
I don't regret the 15 horses on my O' 25 either.
Jun 5, 2010
1,136
Hunter 25 Burlington NJ
Fix the old motor.
Parts for your 1979 motor can be found. Try this guy, in my estimation THE source for Evinrude/Johnson 9.9-HP and 15-HP outboards. You can just about build a new motor from what he has available.
(BTW I have a 1987-88 Evinrude long-shaft/electric start 9.9; and this is the guy I am using for parts.)
:dance:
Oct 4, 2013
18
Hunter 25 Eagle Mountain Lake, Fort Worth, TX
Re: Fix the old motor.
Is there a website or contact number for this guy? Did I miss it? Thanks,
Mike
