Which battery is my bilge pump connected to?
Sep 24, 2018
3,465
Catalina 30 MKIII Chicago
A previous owner labelled one switch position house and the other as start. We've only been using the house battery, even for starting. However, I'm finding that the start battery's voltage is down to 11.5v even though we havent used it. I'm thinking the bilge pump is pulling power from it. Is the bilge pump typically wired to battery 1 or 2 when the battery selector switch is off?
Jan 4, 2006
7,295
Check the terminals on the house and starter batteries to see where the light weight connections are.
If by some weird chance the connection to the bilge pump is further down the wiring, pull the (+) main wire off the posts one at a time to see who powers your bilge pump.
Sep 25, 2008
7,469
Alden 50 Sarasota, Florida
Actually, you have two issues:
1. To which battery is the bilge pump connected, and
2. why is one battery discharged.
as you have been told, trace the wiring. Nobody knows what a previous owner did to energize the pump or how he labeled the switch.
then trace how the two batteries are connected to the charger or via what interconnection, e.g., isolator, ACR, etc… they are interconnected.
Sep 24, 2018
3,465
Yes, I can trace the wiring but I was hoping someone could tell me how catalina wired this from the factory as the manual states that it's on even when the battery selector switch is off
Jan 7, 2011
5,675
Oday 322 East Chicago, IN
Could you take the pos wire off one battery bank, and see if the pump turns on (lift the float to test)?
Do you have a bilge pump switch at the DC panel? If so, I would guess the house bank is powering the pump. But if you disconnect the pos from the house bank, and see if the pump turns on it should confirm.
Greg
Jan 4, 2006
7,295
YES !
They ran the wiring directly from the battery terminals. No ON/OFF switches in between. No battery selector. Just a breaker in between and that's likely on your DC panel.
That's what the manufacturer intended. Check post #8 as most PO's are absolutely out of their minds when it comes to things like this. Nothing is off the table when it comes to PO's. As a matter of fact, @Don S/V ILLusion has listed the conditions under which the PO most likely altered the the bilge pump wiring.
Hi Mayhem,
Here is how one Catalin Owner has his system wired. The bilge pump looks connected to the common of his three-way switch.
May 24, 2004
7,176
CC 30 South Florida
If you feel the need to have an operating bilge pump while you are away from the boat, you could wire a properly fused bilge pump directly to the house battery bank. That way you could turn the batteries switch Off and disconnect all the others circuits. I personally do not think the benefit of periodically expelling incidental water compensates for the risk of having the unreliable float switch getting stuck and killing the batteries. The trick is to frequently check your plumbing system and rain entry points for leaks and minimize them.
Sep 25, 2008
7,469
i have no independent knowledge how true this is - “more boats sink at the dock than while underway”.
if true, it’s a “no-brainer ” to have it always energized. And even if it’s not true, it is still better than relying on luck.
