Which Autopilot system should I buy?
3
Hunter 280 Enoshima Yacht Habor
Hello,
I have an Autohelm ST4000 autopilot system installed on my year 1996 Hunter 280. This 16 years-old system does not accept my order sometimes nor show the "degree, where I want to go" on the LCD display. Threfore, I am now thinking to replace it with new one.
Is the "Raymarine SPX-5 Wheelpilot with P70 control head" currently only one choice for saili boat? Does anyone know if there are any other models available?
I read some owners' review and learned that the reputation for SPX-5 is not so good as well as its predecessor. In addition, the new control head "p70" has blight red screen which does not match other boat instruments that I have(ST-60 series with conventional green backlight LCD).
I asked HunterOwners.com for the availability, but they don't carry autopilot system now. Does anyone know where I can buy Autopilot system at good price?
Thank you everyone for advice.
Kenichi
Kanagawa, Japan
xcyz
Hunter 376
Hate it when they don't accept orders...
Not sure but which ever one you do decide on make sure she also does dishes, floors, windows and washes the clothes.. Oh and cooks too...
Oct 29, 2005
2,366
Kenichi-san, I replaces my ST4000 MK2 with the SPX-5. My experience is the X-5 is much better. Although it gets pretty "sensitive" in course keeping, it takes awhile to learn. Also you could set the rudder and course keeping sensitive to your liking. I have the ST6001 display so perhaps you could change the ST7000 . You can order from Defender or WM.
Fair wind.
Jun 6, 2006
6,990
Can't speak to the "what should you buy" question but it sounds like the nit just needs to be calibrated (run it in a circle while in calibrate mode) to get it to read the direction correctly. You have to do this every year or two and it only takes about 5 minutes and can be done from the helm. just enter calibrate mode, turn her in a nice constant rate turn for at least one complete turn around (till the unit beeps) and exit calibrate mode. It is handy to have the GPS connected to the SeaTalk network as you get the option to "use GPS heading" after the unit beeps and before leaving calibrate mode.
As far as not accepting your input, that could be a corrosion in the connection problem. In most installation the connections are only at the various components and there are none between components.
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
I'm in the same boat, pardon the pun. My ST4000 won't calibrate? Bill, I have tried calibrating, the manual says to circle under 2kts. I have to take it in and out of gear to circle slow but it won't take. Is this a sign the system has died?
I'm a little confused. On the newer model "Raymarine SPX-5 Wheelpilot with P70 control head", does it need the fluxgate compass?
It's part of the package:
http://www.defender.com/product.jsp?path=-1|344|2028687|2028710&id=950311
and not part of another package:
http://www.defender.com/product.jsp?path=-1|344|2028687|2028710&id=1825866
Nov 1, 2011
10
catalina 250 Lavallette
I had the same issue and replaced the fluxgate. Now everything is working.
Jun 6, 2006
6,990
The speed of the boat has noting to do with calibrating. It is the rate of turn. You could do it a WOT and a large diameter circle or just hand rotate the boat at zero knots. It is not how fast you go forward it is how fast (degrees / second) you turn. The fluxgate has no way of telling how fast you are going, only how fast you are turning. In fact it would be easier at WOT as you have more control over the turn with all that water going over the rudder. Since they (going from memory so do look up the rate in the (gasp) manual) want something around 2 degrees / second, that would imply that it should take you 180 seconds to complete a 360 or around 3 minutes. If memory serve the control head will help you control the rate of turn by flashing "slower" or "faster" or some sort of indicator.
The fluxgate compass is an integral part of any autopilot. The units from Raymarine are sealed and you probably threw away a good unit that just needed the wires / terminals on the control box cleaned. The signals from a fluxgate are very low voltage signals which is why they suffer a lot from corrosion and also power carrying cables nearby causing induced voltages in them. Cable routing is VERY important in fluxgate installation.
Jun 6, 2006
6,990
As for the Defender links and what components each needs, I would note that the X-5 does not show or mention any way for the person at the helm to control the unit.
I'd go to the Raymarine site and get the installation manual
