Wheres water in the bilge coming from??
wilf
Jan 25, 2017
124
oday 25 oday 25 long beach
Hi, any oday 322 owners or anyone answer this question , when i took my boat out last week i motored for 5 hours and when i got back there was about 2" of water in the bilge, i know the packing gland drips so next time out i put a dish under the gland so i could see if that was the cause and again motored for around 5 hours again about 2" of water in bilge when i got back and maybe 1" in the dish,
when it sits at the dock for weeks its totally dry, i know the keel and bolts are good, just had it hauled and bottom paint everything was good underneath so i know its not from that, so im just curious where else water gets there from,
When i take out the front step access i can see some water on the port side just in the front of the engine so assume it runs from the engine area to the bilge, anyone know where its from ?
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
You're in Long Beach I see..Have you tasted it? Salt or fresh? Usually the first step for a salt water boat...
My guess is that the water is coming from out side the boat and getting in.
One of the 5 key rules of boat ownership.. Keep the water out side of the boat...
If it's not from the stuffing box but only happens when under power, then could it be some other through hull that only gets close to the water when motoring? Maybe a cockpit scupper or bilge pump outlet that exits close to the waterline. Or the rudder post.
wilf
Jan 25, 2017
124
Thought about the bilge pump outlet but its probably 10" above the waterline
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Check all your hoses. Old hoses can crack and split open. Cockpit scupper hoses, raw water hoses, exhaust hose, raw water hose to the head, sink drain hoses.
kmart
Jan 1, 2012
87
Pearson 10M Fall River, MA
I just went though similar excersize .
My leak turned out to be raw water pump. Only spits water when engine is running. Bearings went. Replacing pump this week. My engine is yanmar 3gm30f
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
you have to check while its under power. When the engine is on, the stuffing box doesn't drip.... it sprays from the shaft spinning so minimal will fall directly in your plate.
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
Is it salt water or fresh? You know how to check ;^)))
wilf
Jan 25, 2017
124
I did check it while running, didnt see any spray from stuffing box, no leaks from hoses that i could see unless its from a hose thats not easily seen, will be down at the boat this week so will check everything that you guys mentioned
Jan 18, 2016
782
Catalina 387 Dana Point
I had 2 leaks it took me awhile to find.
1. Raw water pump - leaky seal. It leaked only while the engine was on.
2. Rudder post. Under power, the stern squatted enough to drop the rudder post stuffing close to the waterline, add the prop wash and it would come out the top.
I only found them by having somebody else man the helm while I crawled around the boat looking for the source.
Pearson P303 #221 RockPort Maine
Wilf ! 1st. I would drain the boats water system to make sure no fresh water is leaking in boat from pressurized hot/cold water "Drain Completely". 2. Check from the seacock to the raw water pump on engine for any signs of leaks and also make sure all hoses are GOOD and clamps are on tight and proper and in position properly. 3. inspect and close all seacocks not needed for testing. 4, inspect and all thru haul electrical sensors "water-speed, temp,..etc for proper position and locked in properly. 5. tie a colored rag around mast to see if water coming down mast. This should help I hope! Now run a quick trip and see what you find. It would be better to have someone drive while you look for leaks on the go.. Stargazer II
Jun 11, 2004
1,937
Oday 31 Redondo Beach
Had similar circumstances on my O'Day31. The engine exhaust on the 31 exits out the transom in an area normally above the water line. When fast motoring though the transom squats and the exhaust is sometimes partially submerged. My exhaust fitting had separated a bit from the transom and it would leak only when it was submerged when motoring (or when washed by a following sea) .You couldn't really see from the outside that it had separated but I found that it was leaking by looking at it from the inside of the engine compartment while motoring. I'm not sure of the configuration of the 322 but that may be something to look at. Relatively easy fix with some sealant and new bolts if that's your problem.
wilf
Jan 25, 2017
124
Well i checked all the hoses and stopcocks theres no leaks there, no leaks from the water tanks, its freshwater thats in the bilge , well it doesnt taste salty? So i still have no idea where its coming from, theres been no rain so its not coming down the mast
SG
Feb 11, 2017
1,670
Hosing down the boat (e.g. hose-downs) can let water in.
Better than salt water.
