Bill O'Donovan
It irked me that I kept getting a cupful or more of water in the bilge from no apparent source. So I took four water samples and had them tested in a lab to see if there was a pattern. The test was for sodium, or salt. 1. Water that seeped in overnight, perhaps while washing the boat off. Showed 9220 parts per million. 2. Water that seeped in after a day's sail. Presumably it came in through the wash of the Chesapeake Bay and York River over the gunwales and through the stanchion posts. Showed 7590 ppm.3. Water taken from Sara Creek, leading to the York and presumed equally brackish. Showed 6600 ppm.4. Tap water from the boat as benchmark for pure water. Showed 18 ppm.What's odd is that Sample 1 contains more sodium than the creek itself, perhaps because it's washing down a greater concentrate of salt. Sample 2 poses the same situation.This is hardly academic. The purpose of the test was to see if water is coming through the bottom, perhaps at the keel. Anyone have any ideas? Thanks
