Mast mounted radar issues
I have a 28-T. The previous owner mounted the radar on the mast, cable down facing the bow on the outside of the mast , and then through the cabin roof using a watertight conmpression type fitting.
Seems fine, but if I lower the mast, (mine swings forward) I'll have to be carefull not to pinch the wire on the pulpit, when I go to rest it. I believe there are likely about 8 wires inside the cable, so easily broken.
Also the genoa sometimes catches when crossing the mast.
If I was doing it, I would go with one of the backstay mounts that will self-level when you are heeled, so that the horizon is not blocked while under sail. Better than a post.
See these guys for an idea:
http://www.waltzmfg.com/products.shtml
This would easier to bring down for servicing, and the mast would block less of the view, being further way.
Regards
