Where to tie off headsail halyard
  • Thread starter Christian Campbell
  • Start date
C
Christian Campbell
Just bought an Oday 240, and am new to sailing. I'm getting ready to raise my jib on it's roller furling, but I can't find any place to secure my jib halyard after it is raised. I can't find any cleat on the mast, or any other place near the mast to tie it off. Where/how should I secure it? Thanks, Christian
James
Previous Owner Mod?
Christian - I have an O'Day 23 so am not familiar with your boat. I have a two cleats one on each side of the mast; One is for the main and the other for the jib. Are there any visible signs of a cleat on the mast? screw holes or an area which has not been aged by corrosion which looks like the shape of a cleat? If you do not have a cleat then perhaps the previous owner did a modification for the halyards to run to the cockpit so that they could singlehand the boat more easily - this is a common modification so I'd suggest looking for some turning blocks and a jam cleat or something in the cockpit area. Hope this helps James
Jun 5, 2004
2
- - Wickfor, RI
roller furling jib
Christian, I too am new to sailing with an O'Day 23. On my roller furler there are small cleats on the roller furling unit just above the drum. I don't think you can run the halyard to the mast because then the top of the sail couldn't spin to be furled/unfurled. Again the disclaimer: I'm a newbie.
E
eric
CDI
the 240 was built with a CDI furler. they still exist http://www.sailcdi.com/ you probably have an ff2. all of the instructions are at the website.
