a few ideas I've seen...
I used to carry mine in the laz. Worked fine for years. Then a few years ago, while singlehanding on a 30 mile passage I got caught in a severe, unforecasted storm. I lost my main when I tried to put in a reef. It took me about a half hour to get it back on the boat...in a wadded clump. Fortunately, I had enough seaway to prevent going on the rocks while I was preoccupied with the main...but I almost did. That's when I decided it was necessary to keep the anchor at the ready on the bow.I now hang my anchor on the pulpit, the challenge is rode storage. I've seen several methods. The bag or milk crate idea is probably the most common; cheap, simple, convenient, effective and ugly.There used to be (might still be there) a site on Macgregor-boats.com showing how a guy removed foam from above the V-berth, cut through the deck and built a very handsome rode locker...extensive fiberglass work, done by a pro.Another way is to use the space between the very front of the V-berth and the bow, installing a deck pipe over it...that space goes into the bilge under the berth. Seems like that might get a little rank with both mildew and the septic odor of sediment...but it's an easy and good looking solution.I built a removable, sealed, self-draining locker that sits on the "rails" of the liner in the very front of the V-berth. Access is through a deck mounted Nicro deck plate with a deck pipe installed on the cover. Holds 150 ft. of 3/8" rope and 10 feet of chain. I love this mod...but it might be harder to do on the S with the foam overhead.
