Where to put a generator on 373
Sjvaun
Oct 28, 2013
6
Beneteau Oceanis 373 Kemah
Wondering where I might put a generator (and what size) in my 05 Oceanis 373 to run the A/C and/or charge batteries. Anybody have any ideas?
Gunni
Mar 16, 2010
5,937
Where ever you place it you can be sure that it throw off he balance of your boat and create a heel. That will affect how you boat sails on different tacks. And it will probably put your boat bow high, which affects your ability to point. I have a NexGen 5.5 and it a well designed generator with the great Kubota diesel as the powerplant, very compact and if you have an enclosure, suitably quiet.
Frankly the 37 is small for a gen install, and the state of power generation has changed radically with better and cheaper solar options, and inverters. The gen set pretty much comes down to A/C on anchor and that is a lot of money to spend for A/C. But, if I were going to do it again, I would go NexGen.
Sjvaun
Oct 28, 2013
6
Understood. I already have the light bow issue with my dinghy up on the arch. I figure I need to add some weight up there other than the chain.
I thought perhaps solar was getting better and maybe Tesla will make a battery for boats.
Jun 21, 2004
3,099
Beneteau 343 Slidell, LA
Saw a 373 that had a genset mounted in the Stbd lazerette.
Don't know how it affected balance & sailing ability.
Jun 22, 2012
9
Beneteau 373 Victoria BC
I am thinking of a Honda 2k and smart start for the a\c at anchor. Not sure where to store it - as much forward as possible perhaps. Just bring it out and lash to the back step when anchored?
Oct 3, 2008
325
Beneteau 393 Chesapeake Bay
I have a 393, only a 2 ft step up from yours. My genset is in the sail locker accessible from the cockpit. On my boat, it's on the port side. The genset is a 4k Fischer Panda.
The list to port is not much affected, that I can tell. It may affect it, but I think it's negligible. The FP is light for its output, but other gensets could be considered too.
A 4k is enough to run the AC and charge batteries.
Likes: Stefan Gashus
