Charles,What is your take on a made up cord?
That is -- does ABYC forbid making up a #10 (10/2 with ground) cable?
In other words can one purchase the cable and the two ends separately -- then install smart plug at the boat-side end and the Hubble standard at the shore-side end?
Charles
You can field install ends and the Smart plug field install end can be installed onto an older Marinco, Charles or Hubbell shore cord. They have a new design for the field install end coming out in the fisrt quarter that makes even more improvements to water integrity and ease of install.
The problem with field install plugs is that they are never anywhere near as water tight as a factory made cord set. The ABYC won't come breathing down your door but some marinas will. Many marina's no longer allow "home made" shore cords for a variety of reasons... I have a connector I came across about 4 weeks ago that I need to add to the Hall of Fail. It was wired BACKWARDS or Hot to Neutral & Neutral to Hot..... This is a prime example of why many marina's have banned "home baked bread" when it comes to cord sets.....
