Where/How did you mount your display on the binnacle? I have two pods on mine that I want to put GMI-20 displays into, and a Simrad EVO2 7" chart-reader. I can't figure out how to install that. The metal loop behind the pinnacle is not really tall enough if I keep my Gemini Pinnacle compass. Even the compass seems to be made to observe while sitting, but I can't see over the cabin well enough to stay seated very long.
How did you run the cables? My Edson does not seem to have anything to keep such cables from interacting with the chains from the wheel.
Thanks
My old thru-hull sensors are just under the rear edge of the v-berth water tank. I'm thinking of putting the puck just aft and port of the speed log on the port side. (Near the old maserator output ) The puck is adjustable up to 22 degrees, and I think it will work there. (Have not tested it there yet) I'm thinking of glassing over the old senor thru-hulls when we get the bottom done mid-summer. Any thoughts on that?
I had two pods with the pyramidal instrument mounts, the stbd one with the AP head, and the other, which I removed, for the old defunct GPS plotter. Since my wife and I stand most of the time at the helm, I mounted the Garmin in it's tilt/swivel mount for instrument visibility whether sitting or standing.
Sounds like your location FWD should work, and I agree with removing the old sensor. Be sure to grind a wide bevel around the outside of the hole, and I would use epoxy with some micro-fiber thickening as glass bonding agent.
Running the cables through the Edson push-push radial system pedestal was a bit tricky, using a stiff fish wire taped to the 5/8" 6-pronged connector on the transducer cable. I went as far aft as I could, and secured in with cable ties the best I could top and bottom. I cut an inverted U-shaped 1/4" hole/slot through the base of the plastic compass support for cable exit leading SE aft. Doing it again, I'djust drill a 5/8" near the bottom of it and get a split rubber grommet to fit.
The photo is from the day we bought her in Feb.
Pete
