Speakers are Murder on the Compass
On our H-35 we installed a Standard LH-5 hailer for travel through fog. The hailer will send out the required signal in order to comply with the regulations for traveling through fog under power, sail, or at anchor or aground. To complement the hailer we bought a remote listen/back speaker which acts like a speaker and a microphone and is very compact (say, 2 x 3 inches). Intent was to install it near the helm so I could steer the boat and operate the hailer remotely (or use the intercom so the helmsperson could talk to the navigator). Couldn't believe the huge deflection it caused on the compass!!! Also, our OEM Ritche was replaced with a W&P Venus. In order to minimize the deflection of this small listen/back speaker, much smaller magnet than your speakers, I'm sure, it had to be placed clear up near the forward part of the cockpit. Another consideration is to keep any speakers far away from your autohelm compass as it will have the same problem. Even a non-magnet item such as a steel fuel tank, such as for the outboard, will affect the autohelm.
