Where to look for a mast...
3
2 1987 26 Vermilion, Ohio
What salvage yard etc. is best for trying to find a used mast ? For a 26 ' 1987 Ericson ?
Thanks,
Ingemar
Tim R.
May 27, 2004
3,626
Walk the local boatyards. Rigrite in MA may have what you need but the shipping would kill you. I also heard a rumor that they may be near the end.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Give Ebay a look
It is fairly common to see masts on ebay. All sizes. Might be pretty hard to find an exact match though. I agree that sleeving it is worth looking at, and can be just about as strong as the origional.
jimg
Jun 5, 2004
175
catalina 27 dana point
When I needed a boom for my last Ericson I found a Catalina part that was very close in dimensions. I had a new one delivered to my marina with a shipment going to the local dealer. Even if you can't get one this way, I would still recommend looking for a match in a Catalina or Hunter, or anything else that would be a close match. Ericson didn't make their own masts. There were only a few spar manufacturers even back when Ericson was making new boats. Many boats use the same extrusion but at different lengths and with different fittings.
196
Kenner Privateer 26 schooner, Carlyle Illinois
Here are some other boats that had the same mast extrusion. If they are long enough.
Isomat NG-28 Mast
Measurements (OD): 5.20" x 3.74" (132mm x 95mm)
Wall Thickness (minimum): .100"
Weight/ft.: 2.19 lbs. Weight/M: 3.27 kg
Moments of inertia: Ixx = 6.24", Iyy = 3.23"
Circumference: 14 7/8" (378mm)
Alloy: 6061-T6
Sail slides: 3/4" flat slides (A006M)
Standard Mast Lengths: 32'6" (9910mm)
Common Mast usage: Aloha 8.2*; Bayfield 25*; Com-Pac 27; Ericson 26; Mirage 25; O'Day 240, 272*; Pearson 27; Watkins 25;
Jun 25, 2009
3
Ericson Mast-Thanks for Feedback !
Good day,
Since new here, not sure how this will be broadcasted, but will soon find out.
RE: mast, I have not decided to let insurance co., buy the boat for $17K, or try to fix it, with sleeving as some suggested.
I like this boat, but...................
Thanks again,
Ingemar
Vermilion, Ohio
Thanks,
Ingemar[/quote]
