Where to find S25 serial number
129
Beneteau 373 Baltimore
I have found the hull id number on the transom... but... it is partially covered by a bracket. Is there another location (manufacturers plaque maybe) where I can find the number. The documentation has the number and I am certain it is correct. The bracket is virtually impossible to remove and I need to register the boat. Any help is greatly appreciated!!
May 11, 2006
31
- - Sarasota, FL
Old Title??
dosent the previous title show the HIN? Is the boat Documented? You could probably look it up that way with the USCG
Denis
S/N
I have an '83 H25 that has the sn on the starboard hull side, up high as viewed from inside the starboard locker. Climb in and take a look.
L
Les
Nope... not inside that locker
The state (SC) has a problem with the exterior serial number being partially covered anyway. Even if I find the backup number (and there is supposed to be one), I may have to put a plate back there too. Thanks to all of you who responded.
