Where to find replacement amp meter (-40 to 40)?
35
Catalina 27 Rochester, NY
The amp meter on my boat has an internal short. Because the meter is a sealed system, I would rather replace the unit instead of cracking open the existing meter and soddering the short. Does anyone know of where I can buy a replacement amp meter? I would prefer to find one that matches the original oil psi and temp gauges. Paul
Dec 15, 2004
34
Catalina 30 Benicia, California
Try Featherman Enterprises
You didn't indicate the model and vintage of your boat, so this may not help. I have a 1980 C-30 and I have been buying all of this type of replacement parts from Featherman Enterprises - www.feathermanenterprises.com.
Bill N
Sep 10, 2005
53
- - Barnegat Bay, NJ
use volt meter instead and reroute Alt to Starter
Are you aware the amp meter was deleted and replaced with a volt meter starting in/around 1988 (albeit by then the universal diesels)? Also, due to possible fire hazards, and strongly recommended by Catalina and the panel manufacturer, the alternator output was re-routed directly to the starter post (the orange wire) instead of taking the 30 foot route to the cockpit panel and then just disconnected at the panel. Lastly, an Amp meter can actually show less information than a volt meter, and by being able to be wired in parallel, eliminates the voltage drop/loss to the alternator output which would otherwise benefit the batteries. Below is the link to the panel manufacture where you can also buy the volt meter (or amp meter if you choose to stay that route -- but do read their 'upgrade information' before you decide not to switch to a voltmeter):
Jun 4, 2004
35
volt meter and orange starter wire
Bill: Thanks for the reply. Can you tell me a bit more about the upgrade wiring reroute? Paul
