Where to find a new fuel pickup tube?
Jul 6, 2013
51
Hunter 336 Société Nautique de Genève
After diagnosing a power loss problem to the fuel pickup tube being clogged, I tried to pull it to inspect / replace it. I unscrewed the fitting on top of the tank and started pulling. Since there's not clearance directly above, had to pull at a slight angle leading the polyethylene tube to detach from the fitting and fall back into the tank.
I now need to replace the tube, which there's no way of retrieving. It would go where the black fuel line is in the photo (hopefully attached to this post). I rigged that temporarily to draw fuel from a backup fuel tank. And it goes in the hole where the cork is temporarily.
The outside diameter can't exceed 14mm or about 9/16". The interior diameter seems like 5/16" as that's the size of the temporary fuel line in the photo.
The boat is a 1995 Hunter 336 with a Yanmar 3GM30F. There is also (hopefully) a photo of the fuel tank rating plate.
Any suggestions on where to source or how to make a replacement pickup tube?
Thanks!
Dan
271
C&C Mega 30 Long Point, Lake Erie
Mine did the same. Bought a length of steel brake line, cut it to the proper length. Emery clothed the end down a few thousands and press fit it in to that elbow shown in your pic.
Been in there near 10 years now, no problem.
Mine was a smaller diameter, but I'll bet if you stop at a local hydraulics shop and they will have stock that will work.
RoyS
Jun 3, 2012
1,742
Available on line from multiple sources.
Feb 8, 2014
1,300
Columbia 36 Muskegon
Mines just a brass elbow fitting with a length of copper tubing soldered in, cut to reach about 1/2" from the bottom. No screen at the end.
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
+1 to Capt JGW... Ours has been that way for at least 20 years. Just pulled the tank for transmission access and all fittings are in great shape.
