I wanted to post this question here because I see in the general area people go Bat $hit Crazy when it comes to electrical issues and battery charging.
Considering that I plan to keep my boat moored to a buoy with no shore power (duh) for recharging, I want to use this solar panel;
http://www.batterytender.com/Solar/15-Watt-Solar-Tender-Charger-With-Built-in-Controller.html
Where do the leads connect? Directly to the battery? To the Pos/Neg bus bars? to the Bat disconnect switch?
Now let me make this question much more complicated;
Haven't decided what battery set -up I will use but I know this much;
- Moving the battery forward to the compartment under the V Berth, the one that goes to the hull, not the lined one. I will make a custom tray.
- My cut-off switch will most likely be flush mounted near the companion-way, either in the step or in the teak side support of the port seat back/bulkhead.
- I'm either using two 6V Trojans in series, or 2 Interstate Deep Cycles in parallel... both types of batteries I can get for $115 each. if I go with the Interstate deep cycle I have the advantage of starting with one battery and adding the second later.
Now, to go double or nothing... I'd like to have two of these Solar Panels, how will that work?
I know there are a few C22 owners here who are pretty smart with 12V systems, so what do you think?
