where to buy a shroud cover…. cap…. protector…. guard…. thingy?
RussC
Sep 11, 2015
1,735
Merit 22- Oregon lakes
I've checked the store and looked everywhere I could think of on the web for some of these plastic shroud adjuster cover caps to no avail. I just need the cap itself, as schedule 100 pvc makes suitable replacement covers. perhaps I just don't know the proper name for them to use in a search. I see these on many different brands of boat, so surely someone still makes replacements.
anyone???
kito
Sep 13, 2012
2,011
Go to Home Depot and buy a 12' length of 1" schedule 40 pvc and a dozen pvc caps and cement and make your own for under 10 bucks.
May 12, 2004
1,505
OK, I know why people put these things on their shrouds. In reality they hasten the corrosion of stainless by restricting the oxygen that stainless requires by trapping moisture. Take a look at your coated stainless lifelines after a couple of years. Go commando. That's all I'm sayin'. Happy New Year.
Likes: justsomeguy
Mar 28, 2014
49
Catalina 30 Hyde Park NY
You can also use a tapered faucet washer......small one inside of half inch water pipe and larger one outside over the top to shed water....Just make a cut to the center of the orifice on the washer to slip over the shroud.
JM
RussC
Sep 11, 2015
1,735
There's a very simple solution to this potential but dubious issue which I'll show you tomorrow. ;)
RussC
Sep 11, 2015
1,735
JM
But at only a buck fifty from the SBO store for the real deal…………..
Oct 6, 2007
1,179
Hunter H30 1982 Chicago IL
I got rid of mine years ago. They were yellowed and cracked, and I knew of the corrosion potential, but the last straw was when I discovered them to be hiding places for some of the biggest spiders I've ever seen.
Mar 20, 2012
3,983
I would disagree..
as much as long term "lack of oxygen" may be responsible for stainless pitting and corrosion, the experts all seem to agree that wrapping the keepers and pins with rigging tape is a great solution to the problem of keeping the keepers in/not snagging lines and feet on them .... yet that practice almost always lets water in under it.
in addition, the coated lifelines are different in that the water works its way in under the coating by getting between and around the individual strands that make up the wire cable... it wicks its way in.
in both cases, the water remains there for a long time and there is no oxygen to protect the metal...
it is my opinion that the open cover such as shown will allow for less contact with moisture, yet still allow the air to circulate around the hardware and let it dry when it does get wet. a few holes drilled in it will allow air to pass thru it and give it additional drying effect.
the only downside is that you cant visually see if there is a problem developing without lifting the tube.... and the inspeting of it is as simple as using two fingers to slide the tube up the shroud, look and let it drop.... with the tube over it, problems other than normal wear dont usually develop...
so from this, its easy to see I am in favor of the protective tube, and will never understand the reasoning for wrapping the pins and keepers with rigging tape, except as a quick. temporary fix...
the only thing worse than gouging your foot on a cotter pin, is having a $75-150 line damaged by it.... 'cuz my foot heals faster than my wallet does.
and another advantage of the tubes, they make great spider nursery's, for those people that like spiders:biggrin:
8,062
I just want to see them. Commando.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
ON a MacGregor there aren't many alternatives because the adjuster hardware is pretty long and you don't want it to snag on rigging, sails, or even your clothes. replacement caps are the right idea unless you want to replace the standing rigging.
Ken
Mar 20, 2012
3,983
Ken
and they commonly foul when rigging the boat, and when trailering, they rub and rattle on the finish of the boat.... with the tubes over them, it solves all the problems.
RussC
Sep 11, 2015
1,735
Exactly. I don't have a fore-sail big enough to worry about sail wear there, but the flipy-flopy adjusters are sure a pain when setting the mast without the covers installed to hold everything straight. Today I did the modifications to my 1" sch 100 pvc covers and installed them on the boat. I still need to pick up some proper 1 3/8" pins and cotter rings to secure them to the shroud adjusters (shown with pieces of all-thread inserted just to hold them in position for photo), but otherwise I'm happy with my new "turnbuckle boots" ;) .
3,983
that looks great, and I think it may prevent them from becoming a spider hatchery...
one thing I might suggest as to the UV rays... even though the parts are relatively safe and PVC does not visually degrade very fast in the sunlight, but it can get brittle. painting them with a "made for plastics" type paint will keep them safer and prevent the yellowing effect, and they will look better for a long time.
