Where to attach tether?
Mar 26, 2011
3,835
Corsair F-24 MK I Deale, MD
No.
For a small boat the safest kind is probably the aluminum locking biners I show on the jacklines. ~ $8-10. If you prefer the Kong Tango biners that West Marine is using, they are also available through non-marine sources for $20.
Spin shackes are not that expensive ($65)....
Update:
The West Marine Ultimate tether is $159. It includes:
2x Kong Tango @ $20
1x spin shackle @ $20
10' of 1-inch webbing @ $0.36
Total $63.60
This is the $20 shackle (Lewmar). There are certainly others.
http://www.shopsoundboatworks.com/l...lesnshfor60s&gclid=CLu21-b0obsCFSUOOgodPxAAuA
And this allows a sailor to customize to his needs. Ends could be knotted or sewn. Sewing strength? I did a little pull-testing of some sample eyes.
http://sail-delmarva.blogspot.com/2013/12/more-testing-stitiched-eyes-in-webbing.html
Just saying there are options other than the catalog. For small boat sailors, big boat tethers are too big, and for many multihulls, production tethers are too small.
Gunni
Mar 16, 2010
5,937
Thinwater: You have said that you do not have snap shackles (load releasable devices) at your harness. Why? Every tether to the vessel should include the ability release the tether under load.
Mar 26, 2011
3,835
First, lest us agree that the final sentence represents an opinion that is widely held, but not a fact. As I said, racing sailing rules do not require them.
a. I do not worry about my boat capsizing. I am a coastal sailor and learned on some very tender racing cats up to 27 feet. Thus, I'm not worried about getting caught under the boat. If I were sailing something tender or crossing oceans I might reconsider. In any case, I suspect I can operate a Kong Tango faster in the dark under a boat than I can a spinnaker shackle and release it under moderate load; I've done just this hundreds of times rock climbing.
b. My tethers are very short (the short one is less than 2' and is anchored to a jack line at waist level when passing the cabin), my jacklines inboard, and I cannot go over the rail. That is a luxury of having a cat (a rough ride up wind is the price). If I had a boat where that was not the case I would have releases.
c. I have known spinnaker shackles to come open. Perhaps they were not closed properly, but the results is the same.
d. A spinnaker shackle takes 2 hands and cannot as easily be operated in the dark. I leave the long leg of the tether attached to the jack line at all times and detach from the harness end when going below, which is the reverse of common practice; it works better on my boat because of the width of the cabin. We keep both jacklines rigged and keep 2 tethers in place, pre-clipped, when their use seems likely.
Perhaps my reasons are cruising catamaran-specific. I would have different practices on a different boat; the tethers on my last boat had releases. I only mentioned the clips on this thread to clarify that it was not normal practice and not to mislead the OP.
Catalina 320 Dana Point
I would not use a "U" bolt for attachment in the cockpit. I would suggest a folding "D" ring. They fold down when not in use so you don't bang into them when not in use.
Good point, My shins are always dinged from the U-bolts and I haven't clipped in for years.
