Where is the cheapest Alcohol?? Orgio 3000 ques
93
Hunter 27 Lake Lanier, GA
for the stove... the pint of denatured at Homer Depot cost me $9 and it will probably have evaporated by my return....is there a cheaper source? Should I buy 5 gallons at Duron? Can i use Isopropyl alcohol? Is it Cheaper? I love my little Orgio 3000 but the Coleman Foldable from the C-22 is way cheaper from a fuel standpoint.....that is unless yall know of something????:confused:
Rick D
Jun 14, 2008
7,206
Gaskets?
Do you install the gaskets before you leave?
Jun 2, 2004
5,802
Never considered the cost because it lasts forever. Don't even know what I have been paying at WalMart. But Rick is right, you have to keep the burners sealed when you are not using them.
Dec 7, 2007
16
Hunter Legend 35 DeGray Lake, Arkadelphia, Arkansas
The small can, (pint?), at Wal*Mart is $5.95 in my neck of the world. I used to get better deals at Ace Hardware, for a gallon of the fuel. Haven't checked prices at Ace lately but need to. I use my oven quite a bit, it's easy to throw a frozen pizza in there and let her go. At dockside, I use a small GE two burner electric cooktop that wedges nicely on top of the Origo cooktop... the gasket seals were missing from my Legend 35 when I acquired her, I need to find a replacement for them...
May 31, 2007
784
Hunter 37 cutter Blind River
A very good question, Jimboyyy. I have been pondering the same. I have been using methyl hydrate in my Origo 4000 but my research shows that ethyl alcohol should burn about 30% hotter. That is significant for the oven. The methyl costs about $11 per gal and the denatured ethyl $32 (Canadian) at Home Hardware. My brilliant son told me to make my own! But I need it now. Any ideas on cheap ethyl alcohol greatly appreciated.
Nov 6, 2006
10,253
DeNatured Alcohol is about $15 or $16 a gallon at Home Depot here..
jotruk
Oct 8, 2008
18
Hunter 27 Lake Whitney
I normally go to a hardware store and by denatured alcohol works great and is only 15.00 a gallon
Dec 23, 2003
61
Hunter 36_80-82 Gulfport, MS
I wish my stove problem was so easy. I've never gotten mine to work. Made my wife sick while I was trying to light it. I put alcohol in the ignition bowl but never got the burner to light. My colman stove fits on top of the burner cover when I need to cook in the galley.
Anybody know of a conversion method to propane?
