rudder break
I just broke my rudder. I ran aground in heavy wind and with a balky motor. I quickly put the motor in reverse to back off. I was really getting battered by the wind and waves. My motor would quit if I went to idle. While backing off ,the rudder swung back and forth, I had trouble holding the tiller. Suddenly the top of the rudder snapped off just below the tiller bracket at the bolt that goes thru the rudder , one side of the fiberglass on the rudder was still intact . I was 100 miles from home. After I got the boat to a slip I cut the top of the rudder off with a saw right in back of the tiller bracket thru the hole that the tiller attaches to the rudder. The aft part of the rudder in back of the tiller bracket was still in good shape. I borrowed a drill and bit and drilled a new hole in that part of the rudder to reattach the tiller to the rudder. It worked well enough for me to sail the boat home. I ordered a new rudder from Rudy right away. I may have tried to fix the rudder back to its' old shape, but I went ahead any way and ordered a new one. It cost $835 shipped to Fl and took two and a half weeks to get it. What a mess. The inside of the rudder was a very dense foam. My old rudder was looking a little worn in the seam at the top edge so maybe it was weak.
